invidia q300 catback install getting check engine light code p0430
Old Apr 28, 2021 | 11:10 AM
RCFNN's Avatar
RCFNN
i did see the o2 sensor wires were a little twisted possible that could be the issue might have to start with replacing those sensors
Old Apr 28, 2021 | 08:32 PM
AlexAviles's Avatar
AlexAviles
Originally Posted by LoSt180
It's 100% an exhaust leak and they just didn't want to take it apart. Only way you can have a failed sensor is if they weren't careful during install and really twisted the wires to the point one broke. The only reason you would need the L-shaped extension is if you have headers installed.
I went thru this when the guy who installed my headers stuck the smaller 2.75" gasket on the front and triggered leaks immediately. I think I ended up getting another smaller thin round gasket and stacked the 3" one on top with the use of copper RTV.
The problem is that the OEM manifold (as well as PPE headers) have a recess for the stock round gasket. The 3" flange on the Invidia exhaust doesn't always exactly seal with the stock gasket, mainly because the outer diameter of that gasket is only a hair over 3". If you (or the shop) used the 2.75" gasket at the front, it deforms causing a leak also. The 3" gasket will sit with the Invidia flange pretty well, but care MUST be taken to keep the gasket centered as the exhaust bolts are tightened up. There's too much slop in that style gasket to just slap in on, tighten bolts up, and expect a good seal. I made a quick video on the Facebook group page showing the gasket issues, might find it and stick it on YouTube for everyone else.
I’d love to see that video. I’ll be installing mine myself in a few weeks.
Old Apr 28, 2021 | 08:34 PM
AlexAviles's Avatar
AlexAviles
Originally Posted by RCFNN
installed a invidia q300 catback after 2 days im getting check engine light code p0430
has anyone else had this problem or could it just be an exhaust leak or bad 02 sensor?
When did you get yours? I’ve been waiting for mine for months because they are sold out everywhere. I hope this means mine will be here for summer.
Old Apr 29, 2021 | 09:24 AM
RCFNN's Avatar
RCFNN
some shop got one in early for me but i heard most companys are backordered til june
Old Apr 29, 2021 | 09:27 AM
AlexAviles's Avatar
AlexAviles
Oh cool, you lucked out. My arrival date is marked for the second week of June.
Old Jul 27, 2021 | 11:50 AM
RCFNN's Avatar
RCFNN
has anyone got worse gas mpg after installing the invidia exhaust? i was getting 19 mpg now im getting 16
Old Jul 27, 2021 | 02:14 PM
SUNNYRCF's Avatar
SUNNYRCF
I didn't notice any drop in gas mileage. I still average just over 18 around town. How many miles on your car?
Old Nov 19, 2022 | 10:03 AM
jim2527's Avatar
jim2527
Bump for comment later….
Old Nov 19, 2022 | 01:16 PM
cvt's Avatar
cvt
I get that on my previous cars I’ve modded.
it’s called loving the sound and hitting the accelerator a little heavier than usual. It doesn’t help we have a V8 and it worsens the situation. lol
Old Nov 19, 2022 | 01:19 PM
jim2527's Avatar
jim2527
I bumped this as a reminder to myself to ask what the leaky exhaust CEL fix was but I found it in another thread.... better/different gaskets.
Old Jan 17, 2024 | 11:49 AM
2020RCF's Avatar
2020RCF
8th Gear
Default 2020 RCF CEL after Invidia Q300 Install
So I know there's a lot out there about this, but a lot of it is older so I thought I'd post just to see. Put a Invidia exhaust on the car....immediately kept getting CEL for O2 sensor. Figured probably an exhaust leak or improper installation after reading everything on here so I had the exhaust guy install Grimmspeed extra thick gaskets after reading someone's post about this. The CEL went away for about a week and now is back on. I assumed it had to be something under warranty so I took it to the dealership....they're saying it's bank 1 sensor 2 that's damaged & needs replacement. I have the feeling this isn't going to fix the CEL so I was wondering if anyone had part numbers/possible link to purchase 1 or 2 O2 sensor fouler spacers...? And does anyone have any experience using these? Did it fix the problem or ? Thanks so much in advance...really appreciate it!
Old Jan 17, 2024 | 12:15 PM
jim2527's Avatar
jim2527
It’s not bad sensor. It’s a bad sensor reading from a leak. I could never get mine to seal. 3 options:
1: Deal with it. I left an OBD2 scan plugged in and cleared the code as it came up.
2. Ditch it
3. Fiddle with the gaskets and sealant.
Old Jan 17, 2024 | 02:00 PM
LoSt180's Avatar
LoSt180
Depends on the specific code. It's certainly possible (and fairly easy) the O2 sensor wires got damaged when reinstalling back into the exhaust. A sloppy installer would fail to spin the wires backward before installing, causing tightly wound wires. If the O2 sensor wires look tightly twisted, then it might actually be damaged. If they look fine, then might just need to revisit my gasket thread and add some copper sealant.
Old Jan 18, 2024 | 11:05 AM
2020RCF's Avatar
2020RCF
8th Gear
Appreciate the responses from my post. Anyone know where to get O2 sensor fouler spacers for the 2020 RCF? Part number, website, anything. TIA!
Old Jan 18, 2024 | 12:23 PM
MCB1970's Avatar
MCB1970
I could never get the O2 extender/defoulers to work for any extended period of time and I tried many different types. You might be better off having an exhaust shop replace the flanges on the Invidia to better match the flanges on the headers.
