Brake squeal
Hi guys,
So I just got new aftermarket pads and rotors. PMU type ps and centric premium rotors installed in the front. Did the bedding the next day at night x5 times and after coming to a stop several times, no squeal. So this morning, while driving in the city about 10 minutes in, the squeal started to come back and gradually get louder. No clue what I did wrong or what happened. Does anyone have any suggestions? Thank you!
It surely is weird, I asked around and some members have the same setup as mine (same pads, rotors) but they do not squeal and have less dust. Not so sure how mine is squealing, maybe I didn't properly bed the brakes and rotors in well enough the first time around? What I did was do around 5-6 hard braking from 60-70 mph to 15-20 mph then repeat. Drove around for a bit but tried not to stop completely at stop signs and then parked my car back at my place. My best guess is to have the shop re-clean them and inspect them for me. Not so sure what else could be the issue.
^^^^Project Mu Type PS is a street pad:
https://speedfreaksusa.com/i-23901800-project-mu-type-ps-ppf150-lexus-rc-f-gs-f-front-brake-pads-oe-replacement.html
It should not be making noise if bedded in properly. Assume you know that during the bedding process you don't stop, but allow the pads to get hot so they will transfer material to the rotors.
Lou
Lou
It should be making noise if bedded in properly. Assume you know that during bedding process you don't stop, but allow the pads to get hot so it will transfer material to the rotors.
Lou
Lou
Ahhh gotcha, maybe I did something wrong on my end. Will have a talk with the mechanic who installed my pads/rotors. Maybe there is still time to fix the problem otherwise I have no clue what I did wrong
