MARK LEVINSON sound system keeps cutting off
Old Aug 7, 2020 | 05:41 PM
RCFNN's Avatar
RCFNN
Default MARK LEVINSON sound system keeps cutting off
anyone else have problems with there mark levinson sound system
sometimes i will be driving and all speakers stop working except for the front dash ones. i have to turn off the car and start again and then they work again
Old Aug 9, 2020 | 08:21 AM
tuscani66's Avatar
tuscani66
IDK but I haven't heard of the amp going bad and only passing signal to half a channel unless the dash is not connected to the amp and only doors/rear are?
Old Aug 10, 2020 | 10:29 AM
OldManRCF's Avatar
OldManRCF
sounds like the amp is overheating and going into safe mode / disabling channels or shutting down all together. Common causes for this are a weak battery starving it of voltage, a loose or bad ground (unlikely if still stock install) & the amp beginning the end of its life (most likely). It will get worse, not better. Good luck with things
Old Aug 10, 2020 | 11:09 AM
konichiwa3's Avatar
konichiwa3
What car battery are you using? Specs on the car battery?
Old Aug 12, 2020 | 09:32 AM
MCB1970's Avatar
MCB1970
I had a similar issue, but all speakers cut off a few times. Fast forward about 6 months and my mechanic disconnected my battery to get to my last spark plug. The radio/nav system totally bricked when he restarted the car. Brought it to the Lexus dealership and they confirmed the radio/nav was dead. Lexus replaced it outside of warranty.
ATT
Oct 20, 2021 09:18 AM
Logic227
Jul 10, 2019 05:26 PM
sheriffwoo
Nov 5, 2013 05:06 PM
peyman
Apr 2, 2013 03:18 PM
hypnotikz
27
Jan 22, 2008 10:04 AM
