To align or not to align?
Old May 15, 2020 | 11:08 AM
adreano17's Avatar
adreano17
Toe changes all the time for a whole lot of reasons and especially on these cars with the big squishy doughnut rear LCA bushing. And I strongly disagree it changes no matter the bushing. I suspect you haven't worked on a fully solid bushing suspension. The only issue with them is stiction, but if you bounce it and it settles to the same ride height the numbers are the same. Not true with rubber or even polyurethane bushings.
I think we are talking about two different changes. You are speaking on immediate changes (per the link provided), and I am speaking the gradual change over time.
My previous car had upgraded polyurthane bushings, so I am pretty aware of operation of those. Understood different bushings may have higher tolerance to overall symmetry (not debating that). However, the gradual changes over time of other suspension components wearing, and changing operation function also plays a part. Of course this is tolerance by the exact driving that you do, and how frequent. Are you in a state with many potholes or smooth roads? Is this a daily driver, or weekend toy? The variables go on.
My suggestion is all cars symmetry will eventually change over time, and not to risk it "appearing to be okay" when it is not. Just saying, a few degrees can be detrimental on any car, why risk it? Better safe than sorry is what I go by to protect the investment of tires.
Old May 15, 2020 | 04:54 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
The only gradual change over time is the degradation of the bushing material, and if you lower the car without resetting the bushings to a neutral position you'll get plenty of bushing wear. Lots of shops make this mistake.
If you don't do something foolish and you're not bending suspension parts, your alignment isn't changing substantially, and tire life on performance cars is relatively short - in fact, a few track weekends and a set of tires is just another consumable like brake pads and rotors. So, yes, different perspective entirely. On any of the F cars, either you'll dry rot the tires because you're saving the car for the next owner, or you'll burn up the tires in a year or two well before bushing wear causes a significant alignment change. Nobody is putting 80k mile tires on these cars, and 20 - 30k is reasonably acceptable for most of us knowing it's going to be a great 20 - 30k miles.
NewGS22
Aug 23, 2019 05:44 PM
heidihidin
Maintenance
Sep 17, 2018 11:54 PM
warmdye
Jan 16, 2018 03:39 PM
bigbwb
Apr 13, 2016 10:24 PM
