How To: Fix Headlights After Lowering
So, the simple fix is to just initialize this system and the headlights will return to normal. The dealership can do this using their Techstream tools, but where's the fun in that?
- Perform Headlight Light Control ECU Sub-assembly LH Initialization (set the zero point of the height control sensor in the headlight light control ECU sub-assembly LH) after the vehicle height changes due to replacement of suspension components or after performing operations such as removal and reinstallation or replacement of the rear height control sensor sub-assembly LH.
- Adjust the headlight aim after performing Headlight Light Control ECU Sub-assembly LH Initialization.
(1) Turn the engine switch on (don't start engine, just double tab the start button with foot off the brake pedal).
(2) Check the fuel level. The number of times the low beam headlights need to be turned on and off is determined by the present fuel level as shown below.
1 : <E
2 : E - 1/4
3 : 1/4 - 1/2
4 : 1/2 - 3/4
5 : 3/4 - F
(3) Turn the engine switch off.
(4) Turn the engine switch on, with the light control switch OFF.
(5) While holding the light switch in the FLASH position (pull it back), turn the taillights on and off 3 times using the light control switch.
NOTICE: Do this step within 5 seconds of turning on the engine switch. (it took me a few tries to get it right)
HINT: If this has been completed correctly, the headlight leveling warning light and "Check Headlight System" on the multi-information display will blink at 1 Hz.
(6) Using light control switch, turn the low beam headlights on and off the specified number of times within 20 seconds.
(7) You'll hear a ding and the warning light will begin to blink. Verify the number of times that the headlight leveling warning light blinks matches the number of times the low beam headlights were turned on and off.
(8) Turn the engine switch off.
Made a quick video:
Relevant FSM procedure attached as well.
1 : <E
2 : E - 1/4
3 : 1/4 - 1/2
4 : 1/2 - 3/4
5 : 3/4 - F
Holding the light stalk position back to FLASH, does that mean pull back away from the driver, or towards the driver? and turning tail lights on/off means you are going from the lowest (1) setting to the third one (3) right under the low beam on setting?
Pull means pull, not push. Pull flashes highbeams, push turns on highbeams. You're pulling here.
OFF means off. (DRL OFF)
Taillights is the same as parking lights. You're going from off to parking (yes, you will go past the AUTO setting doing this). Your 1 to 4 clicks example makes sense, go 1 to 3 three times. Then you'll go 1 to 4 the number of times needed based on fuel level.
The instructions I have provided were a copy/paste directly from the Toyota TIS website, with my notes/tips in parentheses, I paid for a 2 day pass over the weekend. Was hoping to download the full manual, but the website isn't set up for easy downloads.
High beam adjustment?? | Lexus IS Forum (my.is)
just lowered mine and now the check headlight system warning light is on.
