RCF Speedometer Recalibration
Old Dec 30, 2019 | 12:29 AM
Tazz786's Avatar
Tazz786
Default RCF Speedometer Recalibration
Is there any way to recalibrate the RCF speed readings after upgrading to a different size wheel/tire?
Old Dec 30, 2019 | 01:19 PM
05RollaXRS's Avatar
05RollaXRS
No, you cannot change speedo calibration and the general rule is to keep the rotational circumference within + or - 3% of the stock circumference.
Old Dec 30, 2019 | 05:34 PM
Mingofish's Avatar
Mingofish
May be via tech stream?
Old Dec 31, 2019 | 11:28 AM
flowrider's Avatar
flowrider
Veteran: Air Force
You can always use the GPS on your phone. I've always found that to be pretty accurate.
Lou
Old Dec 31, 2019 | 09:18 PM
buister's Avatar
buister
I used the Yellow Box in my IS300 after modding the rear differential with a taller ratio ring & pinion. I sent the car's schematics to the mfr and they came back to me with the instructions on where to splice the box in. The trick is finding the schematics of the RCF.
vioswhite
Mar 7, 2010 08:10 AM
JohnnyCake
Aug 2, 2009 05:01 PM
Xeeeeeem
GS - 1st Gen (1993-1997)
Jun 2, 2006 10:11 PM
Xeeeeeem
Wheels, Tires & Brakes Forum
Nov 14, 2005 02:36 PM
