P4030 cel
Old Feb 5, 2019 | 01:10 AM
Jlesz's Avatar
Jlesz
Default P4030 cel
I just recently installed a borla exhaust a few weeks ago and today the cel light came on. So i scanned the car and the code that comes up is P4030 the catalyst system efficiency is below the required threshold. So my question is this normal?
Old Feb 5, 2019 | 03:24 AM
lexusrus's Avatar
lexusrus
I didn't have any error codes with my Borla exhaust.
Check and make sure the O2 sensors are connected correctly and screwed into the new Borla correctly.....
Old Feb 5, 2019 | 05:03 AM
siredward's Avatar
siredward
A fairly well-known problem I think. The error code is probably P0430 (not P4030). It occurs with me with my Borla very infrequently. Others never get this error. The current thinking (endorsed by RR Racing) is that Borla should have included new exhaust gaskets. I put in new ones just last week and I hope that fixes it. Part number is 90917-06070. About $30 shipped.
Old Feb 5, 2019 | 06:50 AM
luislopezt's Avatar
luislopezt
new gaskets is what is required. sometimes incorrectly installed gasket will cause the issue..... make sure they are not pinched when installed.
Old Feb 5, 2019 | 07:30 AM
LRCSALES's Avatar
LRCSALES
i have header back and the 90 degree 02 elbows installed on the SECONDARY 02s and i occaisionally get that code . just clear it you will be fine if it pops up everyday after clearing you have a problem. Brand new exhaust systems will trigger it a few times or not at all cause the car is getting used to the additional flow
Old Feb 5, 2019 | 11:14 AM
lobuxracer's Avatar
lobuxracer
Tech Resource
Pretty doubtful on the increased flow theory. The O2 sensors are unhappy. Leak sounds like the most likely cause for sure. Lexus uses a fairly complex test for catalyst efficiency and a leak will definitely make it fail.
Jeannienx
RC F (2015-present)
Nov 9, 2017 11:53 AM
Tam4511
Apr 5, 2014 09:14 PM
Tam4511
Dec 19, 2012 02:47 PM
scENFORCER
Aug 13, 2010 06:15 PM
djzapp78
Sep 3, 2008 06:07 PM
