Vibration during hard acceleration after lowering
Old 11-25-18, 10:23 PM
TRANC3
TRANC3's Avatar
Default Vibration during hard acceleration after lowering
Hi Guys,
My car has 24k miles on it and has recently been lowered on Swift springs including rear adjustable camber arms, plus new 20" wheels. I've recently noticed that under hard acceleration there seems to be a slight vibration coming through the chassis. If I had to guess I'd say it was coming from the rear. My question is, has anyone had something similar happen after lowering, and what was the cause?
I don't believe it to be a wheel balance or alignment issue as the vibration is only apparent under acceleration - it goes away as soon as you come off the throttle. The internet suggests something along the lines of CV joints (is still what they are called on a rear drive car?) or bent driveshaft. Any ideas appreciated.
For clarity, the rear is now running about 3° neg camber, and about 1° neg up front. The car is also TVD equipped.
Old 11-26-18, 05:09 AM
Mingofish
Mingofish's Avatar
3 degree neg is pretty high. Rear tires may be slipping during hard launches. Your tvd may be doing something to compensate?
JT2MA71 (11-26-18)
Old 11-26-18, 08:09 AM
JT2MA71
Forum Moderator
JT2MA71's Avatar
Received 1,595 Likes on 698 Posts
It could be wheel hop. Does the trac light come on while it's vibrating? Mine does slip but no vibration, but that depends on alot of things, titres, suspension setup including alignment, tire pressures, etc.
Old 11-26-18, 01:54 PM
yooniverse
yooniverse's Avatar
Originally Posted by TRANC3
Hi Guys,
Negative 3 camber will not cause that vibration.
You might wanna look at the axle or the drive shaft that could of been damaged while raising the car up for the services you got done.
Old 11-26-18, 05:33 PM
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Received 4,080 Likes on 2,472 Posts
Maybe yes and maybe no. -3.0 degrees of camber is enough to induce genuine camber wear on many tires. If you are on summer tires and it is cold outside, you could be getting tire shake, and -3.0 turns even more negative on launch when the rear squats which reduces your contact patch even more. Why did you choose this setting? I would never choose this for a street driven vehicle, and would only choose it for a road course where I needed a lot of cornering traction AND the tires I am running will benefit from this much camber. No street tire likes this much negative camber.
Old 11-26-18, 09:46 PM
TRANC3
TRANC3's Avatar
Thanks for the responses guys.
- the issue is not occurring in a launch scenario, rather a WOT roll on in 2nd 3rd gear - higher rpm range.
- trac light not coming on and def doesn't feel like wheel hop - its a harmonic vibration through the chassis.
- will check the axles if below doesn't fix issue.
- tyre shake from aggressive camber? - hmmm, haven't heard of this but will investigate.
Spoke to my wheel guy today and took him for a drive so he could feel it, and have decided to dial back the -3° to it's original -2° (I can't remember feeling this when this was the setup - mind you it was on OEM wheels). I'll also check to see how the guys are jacking the car up to see if contact with the axle may have bent them. This will get done next week, so I'll update then.....god I hope it's not the axles!!
Oh, and as to why the -3° in the first place, I can't really answer that....I guess they chose that as a safety net for close fitment, but I'm sure we have room to move it back out.
Old 11-26-18, 10:00 PM
1BAD4DR
1BAD4DR's Avatar
It’s gotta be the wheels you put on. If you put the factory rims back on and it doesn’t have the vibration you know your new wheel and tire setup is bad.
Maybe the new setup wasn’t balanced correctly. Maybe you didn’t put hub centric rings?
Maybe a defective rim or tire. Easy to diagnose if you put your factory rims back on and it goes away!!
Old 11-26-18, 10:19 PM
TRANC3
TRANC3's Avatar
That's actually a reasonable approach....might try this first. Cheers
Old 11-27-18, 06:29 AM
jonmonkey
jonmonkey's Avatar
Old 12-11-18, 06:53 PM
TRANC3
TRANC3's Avatar
Just a quick update...we dialed out about 1/2 a degree of camber from the back and it seems to have solved the problem. Issue seemed to stem from reduced tolerance in the driveshaft as a result of running aggressive camber, i.e. it was too tight, exacerbated when WOT as this naturally causes the car to squat, further increasing camber. The adjustable control arm fitted to the rear (SPC in this case) essentially pulls the top of the wheel in towards the car, effectively reducing any play the driveshafts need to operate smoothly.
Still somewhat baffled as I've never seen this occur on another lowered car, and I know a lot of RC-F's run lower than me.
Anyway, happy the problem is solved
Mingofish (12-11-18)
Old 12-11-18, 08:49 PM
Mingofish
Mingofish's Avatar
Thanks for update. Figured it was due to the high neg camber somehow.
3 degrees in the rear is a lot for this car.
Most I’ve seen is around -2.8.
I tried -2.5 at first but my street wheels/tires kept scrubbing the coil springs.
I ended up back at around -1.8 to get both sets of wheels to clear without issues.
Old 12-12-18, 11:43 PM
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Glad you're fixed, but you're looking through the wrong end of the telescope. Reducing contact patch increases stress on the rubber blocks and causes tire shake, especially with street treaded tires. It's not the geometry, it's the tires. It wouldn't do this with slicks.
Old 12-13-18, 05:44 PM
TRANC3
TRANC3's Avatar
Appreciate the comment, and if that was the cause of the issue then we've done exactly what you said and have increased the contact patch of the tyre by reducing camber. Either way it's sorted, and the car is once more capable of breaking laws smoothly!
SoSlow (12-14-18)
Old 02-25-19, 03:57 PM
TRANC3
TRANC3's Avatar
So I wanted to give a further update to this as the fix that we thought had fixed it, actually didn't. I finally had some time to send it in to the shop to try and diagnose....
First thing we did was reinstall the factory rear springs as a way of eliminating possible suspects. Suddenly the problem was gone....literally like someone had flicked a switch. Acceleration was now smooth as silk (I'd almost forgotten how it's suppose to feel). So at least now we knew the problem is focused around the rear drive shafts/axles area and it's components. Of course raising the car means that the camber of the rears was reduced. So once again, we installed the lowered springs but this time removed the SPC adjustable control arms to bring the camber back to something very neutral. At this stage we are all a bit nervous as I've opted for a 295 tyre which is already a squeeze to fit in with 2.5 degrees of camber. Fortunately they still fit....just.
So the upshot is that the amount of rear camber was definitely the issue. We just hadn't dialed enough out when trying to remedy the issue. I'm not sure if it is to do with the tyres (as mentioned above) or if its the angle of the CV's, or if the shaft was getting compressed to a point it wasn't happy. Either way, my question to the forum now is, what's the most amount of rear camber you have run at the rear (at rest), because I could not find this problem replicated on the RCF in any of my google searches....and I know some of you run crazy low.
Old 02-25-19, 06:50 PM
Lammyyy
Lammyyy's Avatar
My drive height runs -2.5 camber and I can launch with no vibrations. Our drive club does 150-165mph pulls from a dig pretty often and I have no issues. Hope this helps!
Sylvan
IS F (2008-2014)
08-30-15 02:36 PM
mikomill
Suspension and Brakes
08-24-12 12:45 PM
monkeybutt
04-23-11 02:14 AM
andykeen
03-04-11 01:43 PM
fireballs gs400
11-09-05 10:07 PM
Quick Reply: Vibration during hard acceleration after lowering
