Requesting Favor - Wing Operation Video
Hello, all.
Just had my wing replaced due to a defect in the CF, and just tested it standing outside with the engine off, and thought it was a little loud going down and dropped suddenly at the end.
Unfortunately, I never bothered to test it the same way before the fix, and never really paid attention to the sounds or operations, so have no idea if this is normal.
The dealer doesn't have another one for comparison, so I'm hoping a few of you could help by posting a video with sound of the wing going up and then down from outside the car, engine off.
Going up you can hear the motor, but everything is fairly quiet. Going down there's a clunk (assuming the lock is releasing) then smooth for a bit, then it drops the last few inches quickly with another clunk.
Appreciate if you could help by posting a few videos.
Thanks!
Thanks!
Hummmm.....I don't hear anything on my active wing going up and down even manually pushing the active wing button with the engine just idling. I was not aware you can operate the active wing up and down without having the engine actually running. I'll have to try it and see. But of course under "normal operation" conditions, I have the Borla exhaust system and under acceleration I really don't hear much EXCEPT for the big V8 ROAR. LOL
Hello, all.
Thanks!
Thanks!
I pushed the on button twice without holding the brake pedal, put the car in "Ignition On" mode....driver window down and stood outside and reached in to hold down the wing button. The sounds and the sudden drop at the end where what I was concerned about.
Thanks!
Quite possible. I will check out the video when I get home and get back to you on this. Don't want to play audio while I am in the office.
A bit hard to accurately gauge because of the door closing in the back. The motor noise sounds quite normal. I think mine is almost as loud. However the 'thunk' noise in the beginning is hard to differentiate as the garage door masks it. Can you make another one without the door closing?
I've attached one with the door open. All noises are the rear wing.
Thanks.
Yeah, that is definitely significantly louder than what I hear from mine. Just a thunk when it drops and a light motor noise. When I am in the cabin, I cannot hear or feel anything while it is going up or down. Also, I opened the trunk a few times and I don't get a whooshing noise. Just a slight hissing noise. That is pretty much it. Hope that helps.
Thanks, bummer, was worried about that.
Anyone else? Can a few others check their wings retracting? Would really appreciate a few more data points.
Personally, though you can drive around with it up all the time, I leave it down - unless parked at a car show / meet or while driving. Hate to suggest it, but there are times a good Service Writer, or Tech at your Dealership will take a look at it without a R.O. Depends on how close you are w yours? Let us know!
