Engine build
Unlike the Chevy LS push-rod engines and others which are easier to modify the Japanese design of this is too complex and old-school as The Car Care Nut puts it in his videos, tolerances are very tight. The other day I saw an LC video with 84K miles, dude was saying it was great for most part but once he did a tune on it, the timing failures happened and the engine is toast so he had to get another engine for more than $20K.
Plus Japanese variants have some sort of Speed limit on these from ECU, they have a Circuit mode (You can see the icon for that in JDM RCFs or Japanese brochure, here's a thread) to unlock the speed, TOMs does sell ECU system to remove the speed limit and as you can see one needs to remove the ECU then send that to Japan to get it flashed and then install plus a dealer reset. Here's one for Lexus LC again the same Circuit mode. So basically the ECU cannot even be hacked to bypass the max speed limit higher than 168-180Mph in USDM.
Supercharging, Nitrous Oxide and Rebuilding of the Lexus-Yamaha 2UR-GSE is not at all worth in my opinion. The moment you change something in the Lexus V8 you will set off something else thereby reducing the reliability factor for this engine. As much as BMW M engines like S58 have a ton of aftermarket community, I doubt you can get away with free boost performance by simple hack like an Android phone bootloader unlock and have no issues, they will also reduce the longevity factor. The pre-facelift variants (2015-2019) are only compatible with the Supercharger that's another point to note.
A few Nitrous Oxide RCF threads...I have always had curiosity on the NOS systems (thanks to NFS Underground 2, Most Wanted & Carbon), there are only a few threads here since it's not fully legal I think the lack of information is showing.
https://www.clublexus.com/articles/s...s-fed-monster/
https://www.clublexus.com/forums/rc-...ous-users.html
That said here's a modified Lexus 2UR-GSE engine by DSport. They have increased the Bore size, HP (542), Displacement (5.6L, which is more than RCF GT3 5.4L) and Torque (440 lb-ft).
Article follows below
https://dsportmag.com/the-cars/lexus...atic-lc-500/2/
So how would we be able to generate more power? We decided to keep it simple and increase the engine’s displacement. Based on the bore spacing and other critical dimensions within the engine, we decided that an increase in bore size from 94mm to 99.5mm would do the trick. We sent the block to LA Sleeve for further inspection and to allow them to take the measurements needed to produce a set of amphibious sleeves for the 2UR-GSE.
Magnus Ohlaker of Club DSPORT machined the block to accept the new amphibious sleeves. These sleeves locate on a shelf machined into the original cylinders which secure to the block by means of a slight interference fit. The process was captured on video and it’s worth watching. The new sleeves were bored to size before being fitted with custom CP Pistons and Carrillo connecting rods. The CP Pistons were designed to deliver the OE compression ratio while the Carrillo rods were designed to handle over 200 horsepower per cylinder. While it’s definitely overkill for now, the engine is capable of handling 1,600 horsepower or more. The completed assembly also required O-ringing of the cylinders to work with the modified factory head gasket which was never intended to seal a 99.5mm bore. While the original displacement checked in at 4,969.5cc, the new engine’s displacement is 5,568.1cc. This raises output of the engine to 525 horsepower and 440 lb-ft of torque. Since the fuel demands are just 12-percent more than the original, we may be lucky enough to have the factory ECU get the job done without recalibration (something we don’t personally have direct access to doing on this platform). In endurance racing configuration with a race exhaust in place, we see no reason why 600 horsepower couldn’t be approached and possibly exceeded.
