How to replace center console ac vent
Old Aug 30, 2023 | 10:09 PM
sliu1's Avatar
sliu1
9th Gear
Default How to replace center console ac vent
Long story short, the vent is damaged and the only way to fix it is to replace the module. Is there an easy way to remove this ac vent module without tearing off the entire center console? Thanks!
Old Aug 30, 2023 | 10:26 PM
I see a tab on the one side that extends wider than the visible portion. Not sure if you can simply pull it forward.
https://www.ebay.com/itm/334500435450
Old Aug 30, 2023 | 10:28 PM
sliu1's Avatar
sliu1
9th Gear
Originally Posted by LeX2K
I see tabs on the side that extend wider than the visible portion.
yes, a lot of people say the entire center console needs to be removed in order to unplug the ac vent, I am just wondering if it is possible to just crack loose the trim that hold the tabs that extend wider than the visible portion then pull the entire vent module straight out...
Old Aug 31, 2023 | 11:02 AM
JT2MA71's Avatar
JT2MA71
There's some pictures of the center vent taken apart here. Might give you an idea, but yes I had to remove the center console and radio and climate control and part of the cluster hood.
Old Aug 31, 2023 | 11:45 AM
sliu1's Avatar
sliu1
9th Gear
what will happen if i just remove part of the plastic gauge cluster hood and start pulling the ac vent module out? why does the climate control needs to be removed? is the center ac vent module locked at the climate control module? Thanks!
Old Aug 31, 2023 | 01:51 PM
LoSt180's Avatar
LoSt180
I would say there's a reason everything online says to take it apart a certain way. You can always just try to do it a different way and see if it works.
That said, while I haven't gotten into the vent portion, the parts of the dash I have taken apart are full of little clips and screws that are designed to go together in a specific order.
Old Aug 31, 2023 | 01:54 PM
JT2MA71's Avatar
JT2MA71
If you are replacing the whole thing and don't mind damaging it, you can probably grab it by the vent flaps, I just remember it's on there snug. On the left side (the instrument cluster side), the cluster hood clips onto it so you need to pop that lower corner off. I cant recall exactly but there may be screws underneath above the climate control. That's why everything needs to come off.
Old Sep 1, 2023 | 02:23 PM
sliu1's Avatar
sliu1
9th Gear
Thanks for the reply. Yeah the one in the picture is broken, it's already damaged so I don't mind it gets damaged further. The bottom line is by pulling the broken vent module out, I don't want to damage the cluster hood clips and the climate control module clips. So I guess I will have to pay a shop 2 hrs of labor to do it the right way then. Wish lexus sells individual vent tabs so that we don't have to pay so much labor to pull the module out...
Old Sep 1, 2023 | 02:33 PM
sliu1's Avatar
sliu1
9th Gear
just dm you
krazykrnbo
GX - 2nd Gen (2010-2023)
Aug 2, 2016 06:55 AM
Mszkickrck
Aug 4, 2014 04:11 PM
The1Ghost
Sep 16, 2013 09:12 AM
Aznteazer
SC400 / 300 Classifieds
Oct 23, 2002 08:22 PM
