Scraping noise and slippage
Hi, I have 2015 rc350 with the 8 speed. Recently I got my trans fluid changed around 72k miles. It was slipping a little in 5th which is why I did it. Took it to a Toyota dealership to do it.
Fast forward to present day, I'm hearing scraping (not grinding) noises from the transmission when changing gears from 2-3 and 3-4 in manual mode. Rarely in 4-5, but no noise in other gears. Slips sometimes in 3rd/4th in normal D selection. Any ideas on what this could be? Drove around 500 miles to get the trans used to the new fluid already. Didn't notice until I rolled the window down, can't really hear it with the windows up.
Bring it back to that dealer. Next time, go to a lexus dealer. You drive a lexus, not a Toyota.
The fluid level in your transmission is probably incorrect. Hopefully there isn't any serious damage. But based off how you're describing the noise, you have damage.
Currently the car drives perfectly fine, the noise is more like a clutch scratching. No noise on light to medium throttle, hard throttle exhibits the noise between 2-3 and 3-4
Original Toyota dealer said it was normal and tried to pin it on a loose muffler bolt. Took it to the Lexus dealership today, crossing my fingers they get it fixed. Kinda guessing it's an overfilled transmission
dannyk1113
IS F (2008-2014)
22
Aug 1, 2022 11:17 AM
Losiracer2
54
Nov 27, 2018 10:22 AM
