Steering wheel vibration?
Old Oct 6, 2020 | 04:03 PM
Fillay's Avatar
Fillay
Default Steering wheel vibration?
Recently mounted 4 Goodyear Eagle a/s and I’ve been feeling vibration in the steering wheel. It doesn’t sway the car either direction and I don’t feel any vibration in the cabin.
Ive had a road force balance today and was told that everything is normal.
Only thing to note would be that Lexus recently replaced my front passenger strut because it was leaking.
Could it be tbe tires causing vibration or can it be something wrong with the suspension? Thank you all
here is a video clip of the vibration: https://streamable.com/e2uqo6
Old Oct 6, 2020 | 06:15 PM
tfischer's Avatar
tfischer
25 Year Member
The only time I ever had steering wheel vibration like that it was due to the tires not being balanced properly. If this just showed up when you put new tires on the car, that would seem to be the cause (Occam's Razor). I solved my problem (many years ago) by having a dedicated wheel shop balance the tires; that is the kind of place that does it best. I'm at a loss to explain why a road force balance did not solve your problem, but tires are not my specialty.
(Upon reflection, I'm not sure I have a specialty, so this advice is provided to you at no charge.)
Old Oct 6, 2020 | 06:59 PM
Fillay's Avatar
Fillay
Yeah I had it mounted at one shop, and had the road force balance at another!
Could it be that the new strut replacement caused a misalignment? I’m not sure if an alignment is recommended after a strut replacement, although Lexus told me I did not need one when they did it.
Old Oct 6, 2020 | 07:47 PM
baggedRC's Avatar
baggedRC
Yes anytime you replace suspension components or mount new tires you will need an alignment.
Old Oct 7, 2020 | 01:50 AM
CLightning's Avatar
CLightning
Are the steering wheel vibrations speed specific like highway speeds? Bring it back. It's obvious sure your wheels (front) have to be RE-balanced. Happened to me, and this was the solution.
Old Oct 7, 2020 | 04:41 AM
Fillay's Avatar
Fillay
i notice it around 50 mph. I’m gonna call them up tomorrow to rebalance. Also going to get an alignment check. Really hoping it’s nothing with the suspension
Old Oct 9, 2020 | 04:35 PM
wthrman2's Avatar
wthrman2
Fillay - An alignment issue should not cause a vibration problem. As others have pointed out, I am surprised a forced-balanced didn't solve the issue but the last time I had a vibration issue that I never could solve (not on my Lexus product), it was related to the Good Year tires - I dislike that brand with a passion. As soon as I swapped them for some yokohama's, the vibration stopped. I wouldn't be surprised the issue is the tire and so bad that even the forced-balance is unable to correct. I am not suggesting yokohama tires, but I feel you should have gone Michelin or something better than Good Year
Old Oct 9, 2020 | 04:38 PM
baggedRC's Avatar
baggedRC
Micheline is the one at to go on tires, smooth ride not noisy at all, only problem is tread wear.
Old Oct 9, 2020 | 04:55 PM
Fillay's Avatar
Fillay
update: So I went to another shop, and they pointed out that the hub centric spacers for my aftermarket rims were not installed on all 4. I did not have vibration before I installed the good years (I removed my michelin PS4S) so I am assuming that the tire shop misplaced my spacers. I went to the original shop who did the install and they said my car never had them.. but I never had any problems before... I was not going to argue with anybody so right
now my car is in the new shop waiting for hubcentrics
matts6887
Aug 15, 2022 01:58 PM
matts6887
Oct 8, 2020 08:30 AM
Lextazy
GX - 1st Gen (2003-2009)
23
Aug 23, 2019 11:17 AM
moses0324
Apr 25, 2011 05:24 PM
hmkim
May 19, 2010 09:56 PM
