Lowering front with springs, will I have alignment issues?
This is howmy ‘15 RC sits on stock suspension: https://ibb.co/zxj7h86
looking to drop just the front to match the rear height with springs (haven’t decided which yet). Will I have any issues with alignment? I’ve seen others mention they had to replace some parts just to get to oem alignment after springs
I used RSR Down sus springs only on the front for awhile. I had no issues getting and alignment done but I also had it done at a shop that specializes in track cars (I do not have a track car) so not sure how a run of the mill alignment shop would do.
Im on the fence about the rear right now because im rubbing in just the rear driver side with 19x10 and 275/35/19 tires. Going to have it realigned pretty soon and see if they can do anything with the rubbing
I was happy with the down sus and thought it equaled out the front to rear gap. I ended up switching to coilovers for the fine tuning ability that you don't get with springs. The super downs drop you a lot so be careful with that. You might consider getting rear tires with a lower AR. I have 20" wheels and have a 35 AR in the front due to ratings not allowing for a 30 and I rub there at full lock. The rears I have a 30 AR and since adjusting my coilovers don't rub unless I hit a significant dip/bump with speed.
ByoungWoo
Suspension and Brakes
14
Aug 2, 2011 11:50 PM
