Touchpad not working on 2015 Lexus RC
Old 02-12-19, 08:59 AM
RealMCR12
RealMCR12's Avatar
Default Touchpad not working on 2015 Lexus RC
Hey guys,
The touchpad is stopped working on my Lexus RC350 Fsport. (2015). Specifically speaking, not able to move between options in the screen. The Home button is still working.
Has this happened to anyone here before and if so, anything i do to reset the system to see if maybe this works?
Thanks,
Old 02-12-19, 09:21 AM
Pittsy
Pittsy's Avatar
Originally Posted by RealMCR12
Hey guys,
Thanks,
Try unplugging the negative terminal on the battery for 10-15 mins. That lets everything power down completely.
Old 02-21-19, 09:11 AM
RealMCR12
RealMCR12's Avatar
I tried unplugging the battery, no luck tho:/
Old 02-21-19, 12:02 PM
Pittsy
Pittsy's Avatar
Hmm. Are you familiar with taking apart the center console assembly? There are plenty of videos on YouTube in case you don't, but it couldn't hurt to take a look and see if any of the wires inside the harness that connects to the remote interface are burnt or frayed or something of the nature. If you haven't already, or are uncomfortable doing that, just bring it to the dealer. Should be under warranty
Old 03-07-19, 04:09 PM
Bimmerbob
Bimmerbob's Avatar
Had mine repaired under warranty, they told me it was $1000 part. Mine failed three years in.
Old 03-09-19, 02:57 PM
lexual_rc
lexual_rc's Avatar
Have you checked your fuses? Are you still under warranty because before taking anything apart, I would have a certified lexus technician look at it, especially if its free. If not, try taking apart the center console. I used this you tube video to take mine apart when I wrapped it.
The only difference I found in the video is that the RC had 3 bolts on the drivers side which need to come out instead of two. It really isn't too complicated at all. Once you open it up, you can inspect the cable which plugs into that unit. A volt meter can also help test if you are getting power.
Good luck bro!
Old 03-12-19, 09:15 AM
RealMCR12
RealMCR12's Avatar
I'm at 54,000+ miles. Warranty was valid unti 04/2019 or 50k miles. I'll need to check myself.
Thanks for the inputs.
Old 01-26-20, 01:51 PM
ChayceSki
ChayceSki's Avatar
Have you found a fix? If so how did you get it to work I have the same problem
BensonTT
RX - 4th Gen (2016-2022)
95
12-20-23 10:50 AM
woojinhan
ES - 6th Gen (2013-2018)
02-22-18 12:49 PM
AJU72
01-25-18 11:44 AM
Superbeast
LX - 3rd Gen (2008-2021)
04-10-16 09:28 PM
kattanh3
05-20-12 02:47 PM
Quick Reply: Touchpad not working on 2015 Lexus RC
