Wheel rubbing
Old Sep 5, 2018 | 05:29 PM
POPOBE's Avatar
POPOBE
Smile Wheel rubbing
Hi guys,
I am new to the RC family. Just bought a used 2016 RC350 F-sport awd, the previous owner changed the wheels, and when I make turns, the front wheels have rubbing noise. The size is 245/35/R20, as I noticed many people with this wheel upsize doesn't have any rubbing issues. I am wondering if anything wrong with my wheels, and what should I do? Thanks so much for any advice.
Here is the pic of the wheels.
Old Sep 6, 2018 | 07:55 AM
undergrou6's Avatar
undergrou6
Originally Posted by POPOBE
Hi guys,
Mine rubs when I do a full turn, it looks like it rubs on the fender liner.
Old Sep 9, 2018 | 01:01 PM
ackileez's Avatar
ackileez
I have a 2015 Rc350 Fsport awd - it does have a sharp turn ratio.
The stock tires michelin Turanza did some rubbing as well, very slight... although sometimes it was just the tires making noise on the pavement due to the angle of turn.
I now have Pirelli Cinturato same size and no noise or rubbing
Old Sep 10, 2018 | 03:34 AM
Dftank2's Avatar
Dftank2
Looks like its been lowered too. I run the same size on my awd and it does not rub but mine is not as low.
Old Sep 24, 2018 | 11:49 AM
LRCSALES's Avatar
LRCSALES
need more pics of the wheels they could be the wrong offsets
Old Sep 24, 2018 | 02:19 PM
POPOBE's Avatar
POPOBE
Did you lower your car?
Old Sep 24, 2018 | 02:20 PM
POPOBE's Avatar
POPOBE
what rim and tire size you are running now? Did you lower your car? Thanks.
Old Sep 24, 2018 | 02:21 PM
jonmonkey's Avatar
jonmonkey
I just lowered mine this weekend and have 20" wheels with no rubbing. The fronts are 20"x9" with +25mm offset on 255/30 tires. The rears are 20"x10.5" with +40mm offset on 285/30 tires.
It probably has something to do with your wheel width or offset.
POPOBE's Avatar
POPOBE
The size of rim is 20*8.5 42mm. Tires are 235/35/20...
Old Sep 24, 2018 | 02:22 PM
POPOBE's Avatar
POPOBE
Originally Posted by jonmonkey
I just lowered mine this weekend and have 20" wheels with no rubbing. It probably has something to do with your wheel width or offset.
What lowering spring you are using? What is the width and offset of yours? Thank you very much!
Old Sep 24, 2018 | 02:25 PM
jonmonkey's Avatar
jonmonkey
RS-R Down Sus
Old Sep 24, 2018 | 02:47 PM
POPOBE's Avatar
POPOBE
RS-R Down Sus
Thank you so much for the reply. I have tanabe nf-210, I think mine should be higher than your, should I have less possibility to have rubbing issue?.. Do you have any idea what width and offset of yours?
Old Sep 24, 2018 | 03:41 PM
jonmonkey's Avatar
jonmonkey
The fronts are 20"x9" with +25mm offset on 255/30 tires. The rears are 20"x10.5" with +40mm offset on 285/30 tires. Height should only be issue if you hit a deep too fast. Tire amd wheel width would be more of a factor for rubbing while turning. Both my wheels amd tires are wider than yours and I don't have a problem. It could be the offset you have.
Old Sep 24, 2018 | 04:49 PM
POPOBE's Avatar
POPOBE
That's weird, I was told that rc needs higher offset... Will lower offset help to reduce the rubbing? Appreciate for the help.
Old Sep 24, 2018 | 06:02 PM
jonmonkey's Avatar
jonmonkey
I thought the offsets were specific to the wheel manufacturer. It could I suppose. Unless you are absolutely in love with the wheels that came with your car I would buy new ones and sell the ones you have. Any of the vendors here that sell wheels can tell you the appropriate offset for the wheels they carry. Rubbing is going to lead to excessive tire wear which means you will be buying expensive tires more often.
