Ambient lighting upgrade
Hello,
I came across multiple post about changing the interior led but nothing correct about the ambient lighting.
So, I have removed my door panel and you can see the component that gives the light trough the plastic lens.
Now, I'm looking to upgrade the led module to have another colour or at least more brillant because from stock the effect is too dark.
If someone can drop some link with what I need because I know nothing about led...
Another interesting DIY thread for the electrical gurus. I'm eager to see if more comes of this...I would love to see red lighting used instead of the factory white, although I don't have the same complaints and think the white actually looks great!
The main thing is to know the exact value of the resistors. In fact on the board we have 3 X 1500 ohms but cannot determine which are parallel or serial. Two possibilities, either to measure with an ohmeter or give the circuit sketch. The photo is not sufficiently clear. With this value, knowing that power is around 13v we can determine the caracteristic of the LED and can found a similar one in other color. It also remain possible to obtain more brightness in modifying the total resistors value but, may be, with less reliability in the time.
I can however wire them into the auto headlight function. That's not an issue at all. When you have it in auto they will come on or off depending on the lights. Or if you manually want to turn them on or off with the headlights on/off that's what they do now.
It's funny because if I test with ANY other lexus LED or my leds, none of them exhibit the clock staying on quirk like this module posted above.
It also seems odd that they used 3 1500 ohm resistors when normally I think I've used a 360-400ohm resistor to take the 12v source and have it power an LED. Seems excessive for that much resistance? Not sure why they did that. I feel that's what is causing an issue perhaps?
-Nigel
