Rear Camber Arm - Opinion Needed
Hi Folks,
I'm thinking about installing the SPC Adjustable Rear Camber Arms on my RC350.
I had these installed on my GS because the camber was outside spec. (I couldn't salvage them unfortunately).
The RC is within spec, but I'd prefer to be more on the positive side of the camber spec for the purpose of maximizing tire life.
I do have the RR Racing lower control arm bushings installed in the front suspension.
Thoughts please. Is it worth installing the camber arms if I'm within spec? Will adding 1° or so of positive camber help with tire wear?
Thanks
Thanks
No need if you're in spec, arms good when you need more adjustments.
-Josh
-Josh
__________________
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
I’m not lowered, and don’t plan to be lowered. I wonder if adjusting to -1.5 at stock height would cause the slight instability you mention?
Also book time for the arms is around 8 hours and calls for removing the subframe. They’re a 30 minute job MAX, the alignment is the tricky part, so don’t let a shop scam you.
Hi Folks,
Thanks
Thanks
What is that alignment sheet from? Because that is out of spec and could use camber arms.
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
