Manual (physical) Key Fail
Old Nov 13, 2025 | 10:03 PM
CLightning's Avatar
CLightning
Default Manual (physical) Key Fail
Will the manual key able to unlock the car if the car battery is disconnected or completely dead? I tried this today and failed. I inserted it behind the driver side handle and turned it cc and ccw with no luck. Now I'm wondering if the lock mechanism to the latch is broken or does it require some power from the car battery to even work? I have a 2016 Lexus RC.
Old Nov 14, 2025 | 10:54 AM
DAVEB1980's Avatar
DAVEB1980
Try WD40 on the keyhole and wait a bit. The keyholes are known to getting sticky over time due to non use.
Old Nov 14, 2025 | 07:23 PM
Viperx's Avatar
Viperx
yes it works without battery. Door handle and trunk are manual mechanism. If you have dirt caked in there or you havent fully inserted the key into the hole it will have issues. By fully inserted I mean its in there to the point that you can barely grasp the key with your thumb and index finger. The plastic portion of the key will be facing downwards
Old Nov 17, 2025 | 11:48 AM
F3Woody's Avatar
F3Woody
Do NOT spray standard WD40 in a lock mechanism! Make sure you use a lock-specific spray like 3-in-1 Lock Dry Lube.
Old Nov 17, 2025 | 05:36 PM
CLightning's Avatar
CLightning
Tried lubricating and turning the key but was limited to about 80 degrees (normal?) in each direction and failed. I called a a locksmith and with the help of an air wedge, he snaked a 5th wheel pin puller between rear end of the driver's window/ weather stripping and J-hooked the door handle. One day I'm gonna have to open up the door moldings to see whats going on.
Old Nov 18, 2025 | 02:56 PM
KennyFSU's Avatar
KennyFSU
It takes a lot of leverage to turn the key, doesn't help there isn't much of a grip on the key. Mine took a few tries but I was able to open the doors and trunk with it.
Old Nov 18, 2025 | 04:38 PM
CLightning's Avatar
CLightning
I was able to get the trunk open with the manual key hoping to fold down at least one of the back seats. Oh well.
Old Nov 22, 2025 | 02:25 PM
gbrtng's Avatar
gbrtng
2nd gear
I wrote a cheat sheet to carry on my phone:
Lexus manual locks - 2022 RC F-Sport
Driver's door - pull handle out, insert key with tunnel up and turn CW or CCW. Remove key, door is now manually unlocked. If the main battery is healthy, the gas door unlocks too.
Trunk - insert key with tunnel forward and turn key CCW or CW, trunk will unlatch. Hint: open trunk lid first and clean the key area - practice a few times. The lock is far left next to the license light.
Do a test run with the fob far enough from the vehicle so it is not detected - simulating a fob with a dead battery.
Carry a charged start battery in the trunk incase the main battery fails.
And check the spare tire pressure = 60 PSI.
Old Nov 26, 2025 | 04:25 AM
Viperx's Avatar
Viperx
Originally Posted by gbrtng;[url=tel:11995217
11995217[/url]]I wrote a cheat sheet to carry on my phone:
or just save the manual pdf on your phone.
pynky01
Sep 17, 2023 03:48 PM
KarenAnne
Sep 8, 2021 06:03 PM
Legend2013
Apr 17, 2019 09:28 AM
AnthonyMJ
ES - 7th Gen (2019-2025)
Dec 30, 2018 05:23 PM
sjgIS350
Jan 20, 2014 10:33 PM
