Coolant leak
Old Nov 20, 2024 | 07:18 AM
humla's Avatar
humla
7th Gear
Default Coolant leak
The reservoir shows under low. I fill up to full. After I drive half an hour, the liquid is back at just below low.
The engine is not getting overheated.
The problem is that I can't get any heat in the cabin. The fan is blowing cold air. Now we're talking about outside temperatures of zero centigrade and below. After driving at highway speed for 5-10 minutes, the heat starts coming. Then the engine has been running at least 10 minutes or more.
The heat should normally, as you know, come after just a few minutes.
I cannot see any traces of leakage. Not on the ground under the car, and not in the engine bay.
The car is RC300H with a 2,5 liter straight four, so it can not be the valley plate issue (only V-engine problem I believe).
Old Nov 20, 2024 | 11:42 PM
CLightning's Avatar
CLightning
You may have air in the system which causes your heat to fluctuate on and off (which can change when you accelerate, decelerate, uphill grade, downhill grade etc. Follow a bleeding process and try again. Can't find the leak? Did you take all the bottom covers off? On my RC, that's how I found the where puddles of pink coolant were accumulating- on the cover and absorbed by the sound dampeners!
Old Jan 3, 2025 | 06:47 PM
dgill24's Avatar
dgill24
10th Gear
I had a similar coolant leak recently and had to replace the water pump. I initially had a puddle under the car. Before diagnosing the water pump, I topped off the coolant and didn't see another puddle so assumed it leaked out while driving.
tsl95
Apr 13, 2019 12:47 PM
Nick12684
Hybrid Technology
Dec 19, 2017 08:31 AM
icetrayz
Hybrid Technology
Dec 11, 2016 08:49 AM
mfalcon
Oct 29, 2016 06:04 PM
HellaInc
IS F (2008-2014)
18
Jan 15, 2014 09:54 AM
