Photoshop basic question - layers
I have two photoshop files, each with multiple layers.
How can I copy just one layer from file one and move it into file two?
You can also drag and drop the layer from the first file to the second file. Just click on the layer and drag it over to the canvas of the second file.
Another tip is if you want to drap multiple layers, just lock the layers that you want to group together and do the same thing.
Hope this helps.
when copy / pasting from a file with resolution 72 pixels per inch to a file with resolution set at 300 pixels per inch, it will appear much much smaller.
Got it over, just trying to figure out how to make it bigger now. It's a border frame that was formerly on a 8 1/2 x 14 now on a 8x10 and is showing up like an inch big
Another way to add layers to become one is by using stamp.
Make a selection on the image you want copied over, then simply stamp on the other file. To move it around, select the image you want by using lasso tool, then transform, apple t or cntl t then move using your mouse or if you want it gradually use arrow keys. Any image being covered by this method will be eliminated.
Or layer it then save it as a jpeg, it'll compress it to a ingle layer.
I'd do the second one for unimportant stuff. But the first one is for more precise stuff.
