Dyno Tested IS200t intake
Old May 7, 2022 | 01:26 AM
sunamer's Avatar
sunamer
Originally Posted by arentz07
I suppose the entire hood could be removed.
I still find the results of the dyno tests to be interesting. I guess if all tests were done with the hood open it's fine as long as ambient air temps were considered. I was actually surprised to see that it's a fairly divided topic on the internet... some prefer to do the test with the hood closed, while others do not. I think that it's probably advantageous for an open-air cone intake as well.
As for the intake itself, I won't knock it as an intake that creates a meaningful power gain is uncommon. What I question is how the intake alone managed to shift the whole powerband up in the RPMs like that. I would have expected a more subtle change. Any idea how that works?
Yeah, the hood would get removed automatically by the airflow. It is a built-in feature of aerodynamic tunnels
The results are interesting, but as that McLaren guy pointed out - it is actually extremely difficult to get the correct WHP reading. Basically, you need support from the manufacturer to calibrate it and put the car in a certain mode, which is usually impossible to do. So, this is why when different dynos are used, they give different results for the same car. Basically, a bunch of assumptions made in the dark. The ballpark figure is correct, and comparing it against the same car on the same dyno is correct, but making absolute measurements (aka getting actual whp reading) is hard.
Problem here is that when you open the hood, the closed stock airbox does not get any more air, but the "CAI" will get more cooler air because the hot air does not get trapped by the hood anymore. In addition, the internal bay volume stays "external" and filter will have less problems finding more air. Trouble is - it is not how that CAI would operate on the road.
This alone (without t and p considerations) is a serious threat to the measurements validity.
Personally I dont care if the stock airbox or CAI wins in a fair "fight". I only care that that comparison is made fairly.
Old May 8, 2022 | 06:40 AM
ScytheDC's Avatar
ScytheDC
I get what you’re saying about making super accurate measurements. But considering that’s a lot of tech that most people don’t have access to, it’s a bit unfair to use that to argue against someone else. We mostly agree that the OP can do better to get accurate measurements, but saying that unless someone goes to Ferrari to test their CAI then their data is useless is also not helpful.
Old May 8, 2022 | 09:08 AM
sunamer's Avatar
sunamer
I agree, and I never implied that only in a ferrari tunnel we could test it accurately enough. Just thinking through and working with what is reasonably available we can get very good results too. .
Old Jul 31, 2022 | 02:41 AM
glacier21's Avatar
glacier21
I think the intake that makes the most Hp is the
AEM at 28hp. It says it’s been dyno tested. Here is the model number
AEM-21-791C
Old Jul 31, 2022 | 01:26 PM
TreysGS460's Avatar
TreysGS460
Well If AEM says so, it must be true!!!
they meant to put a dash between the 2 and 8.
2-8hp lmaoo
sr20mofo
Performance
Sep 24, 2009 02:41 PM
2SwiFt29
Performance
21
Apr 3, 2008 06:09 PM
acl15
Performance
40
Aug 4, 2006 10:48 PM
caymandive
Performance
Jun 2, 2006 03:11 PM
trimless
Performance
Jan 3, 2005 04:02 PM
