SRT Intake Incident
Old Sep 8, 2003 | 03:54 PM
Slytimus's Avatar
Slytimus
Default SRT Intake Incident
The first time this happened to me I chalked it off to a rear occurence but it just happened to me again to it's time to see if anyone else has had this problem. A few weeks ago I installed the SRT Intake and ECU. After everything was connected and soldered the car started right away. A good thing. I guess a week or so went by and under heavy throttle, not full, the car bucked and stalled. It started right back up again but the Check Engine, VSC and VSC Off buttons remained lit on the dashboard. After I got home I disconnected the negative battery cable and reconnected it. That took care of the lights on the dash. Now today the same thing happened. I was at a complete stop ready to make a left turn. Gave the car more than average throttle, it bucked like it was starved for air or fuel and stalled. I pulled off on the side of the road and tried to restart it. The engine cranked and started but immediately stalled again. Opened the hood to make sure none of the vacuum lines had come off. Nope, everything looked good there. After about five minutes of waiting I was able to get the car to start and make my way home. Has this happened to anyone else? The engine was not cold when this happened as I had driven over 20 miles on the highway prior to the incident. If I was to guess I'd say the engine wasn't getting the right air-fuel mixture.
Old Sep 8, 2003 | 04:44 PM
lexforlife's Avatar
lexforlife
bro
did you recheck the wiring conn recheck to make sure wires are not touching each other also i hope you individually wrapped each conn with elect tape securly also when you were fitting the race ecu inside the cover make sure you did not strain any other wire in their
i had the same set up a couple of weeks ago and installed it myself had no problems but i checked and rechecked everything before securing the cover
Old Sep 8, 2003 | 05:05 PM
BLiu's Avatar
BLiu
Default Re: SRT Intake Incident
This has happened to me as well. I am 100% sure that one of the solder connections is either bad or short-circuiting. The ECU is VERY sensitive. Just a very very slight drop in the voltage can cause the car to act crazy. I would check all the soldered connections again and make sure each one is individually wrapped with tape. Good luck!
Brent
Old Sep 8, 2003 | 06:40 PM
LS4fun's Avatar
LS4fun
Stupid question...did you buy the correct intake for the model vehicle you have?
Old Sep 8, 2003 | 07:09 PM
Slytimus's Avatar
Slytimus
Yes I bought the correct intake. When I get a chance I will take another look at the wiring to make sure everything is still intact. Hopefully it's something simple. Worse case scenario, put the stock intake back in.
Old Sep 8, 2003 | 09:25 PM
BLiu's Avatar
BLiu
If you put back the stock intake, please make sure you take the SRT piggyback ECU off as well. Otherwise, you will have another mess on your hands. The piggyback ECU is tuned with the SRT intake on. If you go back to stock, then the piggy back ECU needs to be taken off. Good Luck!
Brent
Old Sep 8, 2003 | 09:30 PM
LXOGOOD's Avatar
LXOGOOD
If the wires and connections look good, the ECU may need to be reflashed at SRT. Before the "Race ECU" came out, I know some IS300 guys had some problems with their's and they sent the ECU back to be reflashed. Hopefully everything works out...
Old Sep 9, 2003 | 02:44 PM
erayd8's Avatar
erayd8
If everything is connected properly, this problem sounds like the traction control is the problem. What is happening is that the ecu thinks the tires are slipping so it shuts off the throttle plates not allowing any fuel or air into the combustion chambers. Didn't you say the traction control light and engine lights came on?
Suggestion-- take it to the dealer and get the codes read. $20 says that is the problem..
Old Sep 15, 2003 | 11:50 AM
Slytimus's Avatar
Slytimus
For those of you interested, I rechecked the soldering of the ECU and it looked like I need to hone my soldering skills just a bit. Anyway I resoldered all the connections and it looks a lot better now. We'll see how it holds up. Thanks to everyone who offered suggestions and a special thanks to BLiu, who suggested it might be a soldering problem.
Old Sep 15, 2003 | 01:12 PM
BLiu's Avatar
BLiu
Glad to be of help! Happy motoring and let us know how it goes!
Brent
Old Sep 20, 2003 | 07:02 AM
koreanpers's Avatar
koreanpers
is your car working now?
Old Sep 20, 2003 | 10:17 AM
Slytimus's Avatar
Slytimus
The car has been running without incident. Let's hope it continues to do so. Thanks for asking.
Old Sep 20, 2003 | 10:48 AM
koreanpers's Avatar
koreanpers
did u get about the same in gas mileage? how about power? is it quicker..does it feel quicker? we just got ours..and i havnt installed it yet...
Old Sep 20, 2003 | 10:54 AM
Slytimus's Avatar
Slytimus
I haven't checked the gas mileage. The car definitely feels more powerful. You don't feel the power off the line. It's when your cruising down the highway and floor it you feel the power come on. Good luck with the installation and make sure you solder your connections well!
Old Sep 20, 2003 | 11:37 AM
koreanpers's Avatar
koreanpers
did it feel like you lost any power on the low end? you know...like when you go from a stop?
