98 GS400 Apexi NEO, your settings?
Old Oct 23, 2019 | 11:51 AM
GRANYZ400's Avatar
GRANYZ400
Default 98 GS400 Apexi NEO, your settings?
Mods are K&N FIPK intake and exhaust. I’m at sea level in North Carolina.
I have an AEM UEGO X-Series Wideband installed already, which is why I’d like to see what settings people with similar mods are running on their NEO. I want an initial target map so I can safely do a street tune and then tweak it from there. I think I may go for 12.5 - 12.8 at WOT based on my initial research.
The NEO goes in soon, so appreciate if someone can share their High map settings with me. I’ll be posting the install video on my YouTube channel to help other enthusiasts.
AFRs at WOT currently range between 12.8 - 13.2.
TIA!
Old Oct 23, 2019 | 12:33 PM
TrueGS300's Avatar
TrueGS300
You won't have to make any base settings since you haven't changed injectors. The Neo will make no difference just being wired in and the car will perform as it is right now until you make an adjustment. So it will be pretty close as is. It's when you change injectors that things get complicated. So you will just have to watch your wideband and make adjustments for various rpms etc.
Old Oct 23, 2019 | 01:17 PM
GRANYZ400's Avatar
GRANYZ400
thanks! I am just after a look at someone else’s fuel added or removed High map so I can see what a tuner may have done. I hear ya on base settings. Thx!
Miata
Performance
Dec 3, 2018 05:15 PM
92sc250tt
Performance
58
Jun 21, 2014 05:02 PM
6SOARER
Jun 26, 2011 06:23 PM
ShaneC
Performance
18
Aug 30, 2006 01:31 AM
