Intake sound?
Old Oct 18, 2019 | 09:50 AM
OldLs400's Avatar
OldLs400
Default Intake sound?
I installed the F-Sport lower airbox filter ealrier and the sound has greatly improved. It's much more entertaining to drive the IS350 now.
Would I get even more sound if I replaced the standard Wix air filter and the rubber intake pipe with a high-flow air filter and a metal/hard pipe?
Or did most of the sound improvement come from just the lower airbox in the complete F-Sport intake kit (which includes the lower airbox, air filter, and hard pipe)?
Old Oct 22, 2019 | 12:54 PM
MikeFig82's Avatar
MikeFig82
The metal pipe will probably enhance the sound a little opposed to the rubber pipe. Though you'll gain some performance with the metal pipe too.
As for the filter I think stock filter performs best.
Old Oct 24, 2019 | 09:29 AM
Gville350's Avatar
Gville350
I have a factory unmodded airbox with a K&N panel air filter in there. It definitely makes additional noise over factory replacement panel filters. Plus, according to K&N, additional ponies due to the increase in airflow (CFM).
Old Nov 10, 2019 | 12:35 AM
SCANDAL's Avatar
SCANDAL
10th Gear
If you want noise. You can also install 14+ IS350 F Sport intake pipe with speaker (not sure what that part call). I install F sport air box, AEM filter, and 14+ IS250 F sport intake pipe on my IS250 and it make my engine sound louder after 3,000 RPM.
Old Nov 12, 2019 | 10:23 AM
Zmon's Avatar
Zmon
Ended up buying one of those actually from a 4GS, dimensions appear to be the same. I'm assuming the metal clips on the ends of the tube, along with the tube near the sound resonator are all reused?
Old Nov 13, 2019 | 07:05 PM
SCANDAL's Avatar
SCANDAL
10th Gear
Yes, I reused my metal clips.
andygill27
Nov 30, 2023 08:57 AM
TJR14IS350
Performance
Sep 28, 2017 06:23 PM
Ants350
Oct 12, 2014 10:38 AM
Karlson
Jun 4, 2010 06:37 PM
CAK 500
Jun 4, 2010 02:45 PM
