Check oil light
Old Apr 10, 2019 | 05:52 PM
Corralesr's Avatar
Corralesr
8th Gear
Default Check oil light
Hi, I’m new here!!!!! Can someone tell me why my oil, and water light keep coming on? My boyfriend has already put about 5 quarts. The light went off and then the water came on? I’ve put water and still it comes on. Also my odometer isn’t reading the correct speed and this happens every now and then. Helppppp
Old Apr 11, 2019 | 05:58 AM
captainva's Avatar
captainva
If he just poured the oil in without checking the dipstick that could cause engine damage. Make sure you have the correct amount of oil in your car and if you're not sure take it to a mechanic. A few hundred at a mechanic is cheaper than a blown engine
Old Apr 11, 2019 | 01:48 PM
MOAWINGS's Avatar
MOAWINGS
If your oil level light is turning on I would advise checking the dipstick. These motors have a sensor in the oil pan. You should verify whether the float gauge that controls the sensor and/or the sensor itself is working properly otherwise like Muffinizer said you could risk blowing out seals and much more.
LEXBOGGY
Dec 20, 2016 09:04 PM
1stGS30
GS - 1st Gen (1993-1997)
Nov 25, 2007 03:26 PM
Brownja
May 19, 2007 10:14 PM
jewelerz
Jan 4, 2003 11:55 PM
