I recently just purchased a 2006 IS250. It has been giving me a P0420 and P0430 code. I have replaced both sensors as well as both Cats. Still getting a cel like with the same codes. Any recommendations or fixes anyone knows about?
Which O2 sensors did you replace AND with what CATs did you replace the previous with?
i used OEM cats and Denso o2 sensors. Replaced both downstream and both cats. Just rechecked code after replacement and it’s actually P0171, system too lean. Now I’m thinking it’s either the upstream sensor, plugs n wires, or MAF sensor.
^A rental fog machine is your best friend if you fear a vacuum leak.
no no vacuum leaks. Cleaned MAF sensor, no luck. Replaced both upstream sensors. So far so good but it’s only been a day so I’ll give it more time and repost an update. Any other suggestions?
