2017 IS200t VRtune
Get a TOM's power box if you're going with a piggyback tune. It's a quality product with proven gains
zhifan1 (06-21-17)
I've had both and my experience was better with the TOMS, it is cheaper in price as well.
http://www.nigel-jdmparts.com
Contact Nigel to see if he has any in stock.
Nigel-JDMParts (04-28-17)
I currently use the vrtune and couldn't say better things about it. I'll say I think the toms might be a lot more safe only because I had an experience with the vrtune. I was running setting 9 had my car on cruise control and all of a sudden my check engine light kicked on and it appeared as if I lost all turbo power. I then pulled over to reset the powerbox to the stock tune and after letting it sit for 30 minutes everything was back to normal. After going to autozone to have them clear the check engine light they told me it was a low boost pressure sensor malfunction. Oddly enough that kinda lets me know it's working by tricking the sensors for more boost. I've had the vrtune for almost a year and still enjoy it. I think the vrtune might push out a little more hp/boost than the toms but the toms should be safer also it's about half the price.
TOM's power box was created specifically for the 8AR-FTS motor and so was the BMS. I've always felt like the VR was a universal box with the right connectors.
...I was running setting 9 had my car on cruise control and all of a sudden my check engine light kicked on and it appeared as if I lost all turbo power. I then pulled over to reset the powerbox to the stock tune and after letting it sit for 30 minutes everything was back to normal. After going to autozone to have them clear the check engine light they told me it was a low boost pressure sensor malfunction. Oddly enough that kinda lets me know it's working by tricking the sensors for more boost.
Just installed Tom's powerbox today, very easy to setup and i fixed it onto the fuse box using the supplied 3M tape. Not floored the accelerator yet as traffic was heavy, but after 30mins of driving, there was no CEL and no weird sounds coming from the engine, so i'm just happy i installed the box correctly, shall test it out more in due time.
New Product TOMS RACING POWER BOX (up your boost) for IS200T
ModInJapan
CL Vendor Products for 3IS
12
10-12-21 09:31 AM
ModInJapan
CL Vendor Products for NX
19
10-16-17 11:21 AM
ModInJapan
CL Vendor Products for 4GS
04-28-17 11:29 AM
ModInJapan
CL Vendor Products for RC
04-28-17 11:27 AM
