You Do Not Need FFIM or Upgraded Ignition!
Old Oct 4, 2015 | 09:45 AM
greasepowe's Avatar
greasepowe
Default You Do Not Need FFIM or Upgraded Ignition!
I figured I would post this so many of you could save time and money!
It keeps all factory functions like cruise control and drive-by-wire because its all stock!
I have 10:1 VVTI/ 272 cams/ 7675 jb/ pro-efi/id2000/ LS400 TB stock intake, stock ignition(factory wires)
As you can see the first two dynos are low because my 3" exhaust was restrictive and we pulled the mid-pipe and went 944hp.
The ignition started to give a little, and I could have gapped the plugs down. But I ordered a set of Magna Core 8.5mm wires and right now having a full 4" exhaust made.
Hope to report over 1000 on stock ignition and Intake manifold after FL2K15 is over and my shop can make the exhaust.
david
Old Oct 12, 2016 | 07:22 PM
stheodore's Avatar
stheodore
David,
Hahaha, I didn't even know your screen name here but figured out it was you anyway from the description of the car/mods. Badass my brother!
Steve
Old Oct 14, 2016 | 07:41 AM
greasepowe's Avatar
greasepowe
This is with magna core wires, this was done last year.
The numbers are deceiving because I'm running v160 with stock 5spd gears. So the ratios are off and do not load up the dyno correctly. My tuner says it is closer to 1100hp.
Hi Steve, come down for "Wanna Go Fast" even 28th. 29th? Going for fastest 4 door.....I got some MT radials for the event!
Old Oct 14, 2016 | 08:03 AM
stheodore's Avatar
stheodore
I knew your car had more in it, thanks for sharing the latest dyno!
If I wasn't so broke/busy, I'd come cheer you on. Best wishes to win your class with that badass IS300 man.
Old Oct 14, 2016 | 08:26 AM
greasepowe's Avatar
greasepowe
It has actually more left on table, this on 34psi, I'll be running 40lbs+ at the event.
Also I'll trade you for your GTR plus cash on my end !!!!!
I may be taking this turbo off my car because the exhaust wheel is a bit restricive and put it on the Supra.
Old Oct 14, 2016 | 09:20 AM
stheodore's Avatar
stheodore
Hahaha, wife would kill me if I even mentioned getting rid of the GTR, that's her favorite car. If I buy your IS300 it will be a cash in your hand kind of deal only.
But, I'm really thinking about starting to build mine now...meaning January 2017...so we'll have to talk soon. Your car is so much more over-the-top than I want to buy/build, but there is no denying the terrific lengths you've gone to in order to build it. Truly exceptional build.
LexISguy
IS F (2008-2014)
17
Aug 29, 2016 06:17 PM
Rider
IS F (2008-2014)
44
Jul 20, 2011 06:51 PM
houstonT
IS F (2008-2014)
31
Sep 27, 2009 09:31 AM
lengnoou
Nov 16, 2008 03:09 PM
