IS250 RWD Transmission Swap?
Old Sep 14, 2015 | 05:51 PM
MDHLexus's Avatar
MDHLexus
Default IS250 RWD Transmission Swap?
Just curious if a manual transmission swap has been done on an automatic is250 rwd. I did some research and all i got was that it was possible, not that its actually been done. Kind of interested. I did the manual transmission swap on my buddies e46 m3 which a lot of them do, so i was curious if it is possible for our cars.
Also... gearing. I know we can swap in the frs/brz LSD. But is there any reputable after market gearing offered for our car?
Old Sep 15, 2015 | 03:24 PM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
As far as the differential goes, there are a lot of gearing options available from 2.9:1 all the way up to 4.78 (or even higher).
Jeff
Old Sep 15, 2015 | 06:52 PM
MDHLexus's Avatar
MDHLexus
Jeff
Like direct differential swaps? or we can buy different gearing to put in?
Old Sep 16, 2015 | 08:10 AM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Direct differential swaps limit you to 3.58, 3.73, 3.91 and 4.10 for factory options from Toyota/Lexus. Other ratios are available as gears only that would need to be installed.
Jeff
Old Sep 16, 2015 | 02:16 PM
MDHLexus's Avatar
MDHLexus
Jeff
Do you have a recommended brand or location to buy em?
Old Oct 5, 2015 | 02:50 PM
svelt's Avatar
svelt
Have you made any progress into researching this? It's something I might consider in the far future (the 'C' is basically impossible to find in manual configuration).
Old Apr 11, 2016 | 12:50 PM
MDHLexus's Avatar
MDHLexus
Have not made any progress into researching this, I thought there would be a lot more out there..
Eric250
May 17, 2025 03:33 PM
IS250Jay
Performance
40
Sep 16, 2022 10:33 AM
potatomon
Jan 26, 2019 01:24 AM
JCE102JZGE
Performance
Jan 27, 2006 12:11 PM
