lexus service looked at my car, and found nothing. code wasn't able to provide anything. even with
no check engine light, the car seems more hesitant from complete stop to acceleration. they may
change the fuel pump, as long as warranty covers it. i'll find out for sure on monday.
I've had Lexus of Portland (Oregon) try to cure my low-idle issue three times thus far. The first two times, the low idle was evasive enough that it didn't do it while the car was in the shop.
A few weeks ago, with the warmer weather--which seems to cause the problem, I let them take another crack at it. This time they decided to clean out the carbon build-up in the throttle body--which isn't covered under warranty, but they were nice enough to do gratis. This change seemed to reduce the roughness by about 50%, but it was still idling below normal speed.
The next day, on the way home from work, I was slowing down to turn off of a highway (thankfully) when I felt a lurch, and the "Check Engine" and VSC warning lights on the dashboard popped on. The engine was idling around 1500 in Drive, and when I tried to press on the gas pedal, there was no response. I limped into a parking space in the parking lot I was turning into, and called Lexus of Portland.
To make a long story short, my GS400 was towed (how embarrassing!) into LofP and they diagnosed it as a throttle actuator motor failure. There is a backup throttle cable, but my understanding is that it doesn't engage unless the accelerator pedal is depressed much further than normal--not something I wanted to try while maneuvering around a parking lot.
They ended up having to replace the entire throttle body, as the throttle actuator motor was not available as a separate item.
I would like to comment that Lexus of Portland made the very best of a bad situation. Everyone from the service advisor down to the fellow who shuttles cars around the parking lot expressed his/her apology for what happened. I was given an '03 ES' to use while my car was out-of-service.
With the new throttle body, the idle is still lower than normal. So couple this data point with the original poster who commented that he had his throttle body and MAS replaced and it corrected the low-idle issue and it looks like it may be the MAS that's causing us grief.
(Toy description: Cinnabar red '99 GS400 with rear spoiler, Nak' package, and 17" factory rims)
What's the idle you guys are getting when the car is fully warmed up? Let me rephrase that.....while you are at a complete stop in DRIVE. What's the idle? Is it between the 2nd & the 3rd line?
Is this with everything off? Well, except the daytime running lights right?
I've test drove several GS4s and most of them idle between the 2nd and 3rd mark and felt fine to me. Only one was slightly rougher than the rest.....hmmmm
Ok, so i took my car into the Lexus dealership and told them that my car idles very low and while coming to a stop it has stalled and the only way to keep the car from being very rough at idle is to have the ac on. Well I went to pick my car up because they said it was ready and bam, THEY INSTALLED AN ENITIRE NEW THROTTLE BODY. Guys, what a difference. The car idles like it should, you can't even tell the car is on while in drive at a light, the car is much quicker to respond to me gunning it since the throttle body is brand new. I guess there was a service bulletin or a recall for the low idle issue because another dealership is also replacing throttle bodies as a cure to the issue. I have to talked to 3 other owners at the dealership who had the same issue and had the thottle body replaced and they say there car is like night and day still after a month. I am in shock to how quick and responsive my car is now. They replaced the throttle body and the Mass Air Flow sensor. Good luck to everyone.
