Transgo shift kit for a650?
Old Aug 14, 2019 | 03:59 PM
  #31
Sin1UZFE's Avatar
Sin1UZFE
Would this resolve whining issues?
Old Aug 29, 2019 | 09:15 AM
  #32
Tank's Avatar
Tank
I think you have a bigger problem if your tranny is whining.
Old Aug 29, 2019 | 10:05 AM
  #33
Sin1UZFE's Avatar
Sin1UZFE
Thought so too but narrowed down to valve body
Old Aug 31, 2019 | 07:11 PM
  #34
Tank's Avatar
Tank
Can't help you there man. Haven't come across a problem like that yet. good luck
Old Aug 31, 2019 | 07:34 PM
  #35
Sin1UZFE's Avatar
Sin1UZFE
No worries, 2 mechanics, reputable ones agree.
Old Aug 31, 2019 | 08:21 PM
  #36
Tank's Avatar
Tank
perhaps swap out the VB with a used one? They also have the the factory service manual for the A650e floating around on the "Internets" somewhere.
Old Aug 31, 2019 | 08:22 PM
  #37
Sin1UZFE's Avatar
Sin1UZFE
Currently looking for a used one.
Old Sep 1, 2019 | 07:04 PM
  #38
Tank's Avatar
Tank
Good luck.
Old Sep 1, 2019 | 08:04 PM
  #39
Sin1UZFE's Avatar
Sin1UZFE
Good luck.
Thanks
Found one 2 he away for 100...says it only has 150k miles....it's only 100
Old Sep 8, 2019 | 04:58 PM
  #40
EuroWill's Avatar
EuroWill
My guess is your valve body is not whining, but you are hearing the whine resonate through it because the pan is the thinnest part of the transmission.
For what it’s worth, I am an ASE, Nissan, and Infiniti Master Tech. I have never heard of a transmission whine unless it is a CVT or low on fluid.
Will
Old Sep 8, 2019 | 05:22 PM
  #41
Sin1UZFE's Avatar
Sin1UZFE
Will
Sounds like a supercharger whine for 1st 2 gears and fluid is full
Old Sep 8, 2019 | 05:39 PM
  #42
EuroWill's Avatar
EuroWill
Whining is usually caused by rotating parts. I suspect it is something such as a bearing in the gearset that is either loaded or unloaded in 1st and 2nd. I will try to find the 650 repair manual online when I get home to see if I can provide assistance.
Old Sep 8, 2019 | 06:16 PM
  #43
Sin1UZFE's Avatar
Sin1UZFE
Thanks but the reasoning is, the transmission was replaced but the valve body turned out to be ****. So the old valve body was reused. And the noise was brought over. No slipping or unusual shifts otherwise
Old Sep 21, 2019 | 07:25 PM
  #44
Tank's Avatar
Tank
Any luck?..............
Old Sep 21, 2019 | 07:27 PM
  #45
Sin1UZFE's Avatar
Sin1UZFE
Haven't done it yet
