Mechanical Limited Slip Differential?
Old May 21, 2014 | 12:49 PM
carderoni's Avatar
carderoni
Default Mechanical Limited Slip Differential?
Anybody know which models, if any, of the 3IS come with a mechanical LSD? I'm not talking about the pre-torque, semi-LSD but like what the IS-F has had for a while now. I don't have my manual handy and lexus.com doesn't seem to list it either way.
What I'm really getting at is, when I completely disable traction control, what if any safeguards do I have? Am I still running an open differential like my old SC 400?
Old May 21, 2014 | 02:47 PM
nayuta's Avatar
nayuta
From what I remember I don't think any of the 3IS have a mechanical limited slip right now.
Old May 21, 2014 | 07:33 PM
4TehNguyen's Avatar
4TehNguyen
they have open diffs
Old May 22, 2014 | 06:29 PM
carderoni's Avatar
carderoni
Thanks, I thought that might be the case.
Old May 23, 2014 | 07:28 AM
redspencer's Avatar
redspencer
OG Member
Veteran: Marine Corps
The 3IS utilizes a brake-based eLSD as part of the VDIM system like the 2IS and 08-09 IS-F models. In regards to your question on what safeguards are availabe when VSC is disabled, I know that for the 2IS, the eLSD function is disabled when VSC is turned off. On the 08-09 IS-F, the eLSD remains active and can only be fully disabled via the pedal dance.
I am curious to know if the eLSD on the 3IS remains active when VSC is turned off like the 08-09 IS-Fs or if that functionality is also disabled like on the 2IS. The way to determine this is to take a sharp turn while VSC is off, apply a moderate amount of throttle, and sense if the the rear brakes are activating on the inner rear wheel which would be an attempt to reduce inner wheel spin. Then you'll know for sure if you do have some safeguards available with VSC off.
Old May 29, 2014 | 08:08 AM
reyoasian's Avatar
reyoasian
the ISF LSD bolts on to the 2IS350, not sure about the 3IS350.
Supraman16
IS F (2008-2014)
211
Jul 11, 2023 05:55 PM
wing
IS F (2008-2014)
16
Jun 21, 2015 10:59 AM
Christan
IS F (2008-2014)
92
Jun 4, 2012 04:22 PM
Joe Z
IS F (2008-2014)
82
Jun 2, 2012 10:15 AM
pjcar41
IS F (2008-2014)
Apr 2, 2008 06:36 PM
