engine help
Old Apr 2, 2014 | 06:43 PM
sawyer2457's Avatar
sawyer2457
Default engine help
I need to know if there is anything else my 2jz ge will need. This is the parts i plan on purchasing but i want to make sure i have a list of everything i need before i start buying parts.
SRT Billet Intake Manifold for 2JZ-GE
Throttle Body Size : 90mm(+$65)
Pro Street Supra 2JZGE NA-T Turbo Kit - 400-600HP
Wastegate : Precision 39mm Black
Compressor Options : Standard Cast
Turbine Housing Coating : Standard Cast
Ceramic Manifold Coating : No Coating Required, Raw
Shipping : Free Lower 48 States
Intercooler : Yes, I want a FMIC Kit, Add
BOV Style : NGR Type S, add
Boost Control Solenoid : Yes, add
Midpipe : Not needed
Dump Tube : Yes, Add
Titan Downpipe : Not needed
Turbo Hardware : Stage 8 Locking 4 Bolt and Nut Kit, add
HKS Carbon Titanium Hiper Exhaust Lexus IS 300 Rear Section
Titan Motorsports Ultimate Race Piston
Select : .020
Brian Crower BC 2JZGTE Connecting Rods
Lexus IS300 Return Fuel System Set-Up Package
HKS Cam Gears Toyota Supra 1993-1998
Brian Crower BC 2JZ-GE Cams
Cam Profile : BC0312, 272°
Upgraded Springs and Retainers
Ferrea 2JZGTE Valve Spring Exhaust
Ferrea Valve Spring 2JZGTE Intake
3.4 Liter Stroker Crankshaft BC 94mm 4340 ISO Billet Chrome Moly Stroker Crankshaft
Old Apr 3, 2014 | 01:33 PM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
What the heck are your power goals?
Without taking the time to add it up, you've got a 10-15k build there...
What transmission do you intend to put behind this?
Some of those parts are good for 1200+ hp, but a lot are not needed for the turbo kit you are buying...
Old Apr 3, 2014 | 05:25 PM
that2JZguy's Avatar
that2JZguy
Oh boy.
...You know the stroker crank can't be used with those rods or pistons right? And in order to build a 3.4L you're looking at $6-10k in PARTS ALONE depending on whether you want to go Brian Crower or HKS, and then you're looking at $3k in machining PLUS billet mains and honing (another $2k total).... And that's just the block...
...Billet crankshaft aside, the Titan race pistons and BC rods are a great combo for a built 3.0L. I have CP 9.5:1 top and side coated pistons with upgraded .200 (IIRC) wrist pins and I'm pretty sure the Titan race piston you have picked out is exactly the same as what I have.
But to be totally honest, I think you should do a bit more research into what it actually takes to build a 2JZ instead of just window shopping around for stuff.
jzz30fan
Apr 17, 2017 03:22 AM
scviolence
SC400 / 300 Classifieds
Dec 15, 2014 03:08 AM
MongolKhan
Sep 14, 2005 07:24 AM
93gt3000
Sep 3, 2005 02:14 PM
chitwnsazn
Jun 9, 2005 04:49 PM
