Wheels on 3IS
Old Feb 19, 2014 | 09:51 AM
Kurmaz's Avatar
Kurmaz
Default Wheels on 3IS
I want to put BBS RGR wheels on my is whith the following characteristics
front 18x8 +40
rear 18x9 + 42
I’m not sure that the above set of wheels will fit my car without any changes in suspension.
I don’t want to buy wheels and in the end have problems with rubbing the body of the car, contact tires and suspension components.
Your opinion will that set of wheels fit 3IS RWD?
Inform please which sizes have your non-original wheels.
Old Feb 19, 2014 | 10:01 AM
jcheng's Avatar
jcheng
It will fit. They are pretty close to stock wheel size.
Old Feb 19, 2014 | 10:21 AM
Kurmaz's Avatar
Kurmaz
Thanks for you opinion.
However, I have doubt.
https://www.clublexus.com/forums/bui...-thread-4.html
He put 5 mm spacers and there is practically no place between the wheels and wheelarch
It means that he reduced the offset form 45 to 40 in front and from 50 to 45 in rear wheels
I suppose that if i put rear wheels 9J wirh +42 offset they will stick out.
Old Feb 19, 2014 | 11:16 AM
jcheng's Avatar
jcheng
He's dropped if I remember correctly.
I ran 18x9.5 +40 with 265/35/18 in the rear before without any issues. Your 9 should have no issues.
Old Feb 20, 2014 | 05:08 AM
Kurmaz's Avatar
Kurmaz
9.5!!!!!!
Did you drop your car, or make any changes in suspension?
Do you have any photos? Is it possible to have a look at them?
Old Feb 20, 2014 | 05:49 AM
larry13's Avatar
larry13
i have 19x8.5 front and 19x10 in rear on stock suspension if that helps
Old Feb 20, 2014 | 06:31 AM
jcheng's Avatar
jcheng
Not anymore. I was not dropped.
I'm running 18x8.5 on all 4 corners now.
R0shiro is running 19x10 on all 4 corners!
Old Feb 20, 2014 | 07:02 AM
Kurmaz's Avatar
Kurmaz
I've read your post - good wheels. Looks great on white 3IS
Saying "without any changes in suspension" i mean that i don't want to install coilovers or make changes in wheel alignment camber.
Old Feb 20, 2014 | 07:05 AM
larry13's Avatar
larry13
Originally Posted by Kurmaz
I've read your post - good wheels. Looks great on white 3IS Saying "without any changes in suspension" i mean that i don't want to install coilovers or make changes in wheel alignment camber.
thanks. not sure of the alignment camper but i am not on coilovers or down springs
Old Feb 20, 2014 | 07:06 AM
Kurmaz's Avatar
Kurmaz
I don't want to instal coilovers, because in russia very low quality roads and i don't want to have problems with guarantee.
I just wnat to remove my stock wheels put new wheels which i really like without any changes in suspension
Old Feb 20, 2014 | 07:09 AM
larry13's Avatar
larry13
I don't want to instal coilovers, because in russia very low quality roads and i don't want to have problems with guarantee. I just wnat to remove my stock wheels put new wheels which i really like without any changes in suspension
roads in Chicago is bad as well. so thats why i wont change anything either. my wheels wont be an issue with gaurantee i dont think.
Old Aug 12, 2020 | 09:14 PM
SMKS's Avatar
SMKS
I just had 18x9.5 +39 in the rear with 255/40 without any issues. The tires were a bit stretched though.
beanders
Nov 19, 2016 03:43 AM
radicalrev
Nov 18, 2007 02:18 PM
AZDesertGS
Wheels and Tires Classifieds
13
Apr 29, 2006 05:34 AM
codetoad
Wheels, Tires & Brakes Forum
Jan 1, 2005 05:11 PM
Furuoka
Mar 2, 2003 09:11 PM
