1998 Lexus GS400 P0172, P0130, P0133, P0150, P0153
Old 11-22-13, 07:59 AM
ThomasGS4
ThomasGS4's Avatar
Exclamation 1998 Lexus GS400 P0172, P0130, P0133, P0150, P0153
Hey folks,
today, my GS threw these codes. I had troubles with the P0172 a while back, but replaced the pre-cat O2 sensors with Denso units, which seemed to fix it for a while. Now, I'm not sure what to think. Any pointers would be much appreciated!
Old 11-22-13, 09:12 AM
sakataj
sakataj's Avatar
thomas.....u know how to search i know u do sir
here's one, start @ post # 9
https://www.clublexus.com/forums/gs-...converter.html
and if that doesnt help, try searching each code individually :P
Old 11-22-13, 09:50 AM
ThomasGS4
ThomasGS4's Avatar
Geez Brian, you know me better than that.
Old 11-22-13, 09:53 AM
sakataj
sakataj's Avatar
i tend to think so
lol i was a tad busy so that was the first one i pulled up
Old 11-22-13, 10:03 AM
ThomasGS4
ThomasGS4's Avatar
With that have been said, I'll add a few more details:
P0130 & P0133 are associated with the Bank 1 Sensor 1.
P0150 & P0153 are associated with the Bank 2 Sensor 1.
My question is, why would I be receiving these codes when I had both replaced with Denso units a while ago? What else could be triggering this?
Old 11-22-13, 12:21 PM
Sampak
Sampak's Avatar
You sure the wiring isn't frayed (filleted)? Could be the old harness going to each O2 sensor is brittle and possibly shorting depending on the vibrations, etc.? I read your long thread on the weird O2 problem that a couple techy guys tried to help you with, seems like if the Denso (which are Toyota OEM as far as I know) sensors worked then, then there's either something causing the sensors to go out, or there is a wiring fault somewhere. Wild guesses of course, just in case you haven't checked those things.
Old 11-22-13, 01:15 PM
ThomasGS4
ThomasGS4's Avatar
I certainly wouldn't rule it out, although I haven't had a chance to take a peek under the car.
GS4IV
11-13-13 07:42 AM
Skew
05-06-12 10:48 PM
yb4in
04-04-12 08:20 PM
mtparker18
06-27-11 12:56 PM
UncleRay
12-10-08 01:18 AM
Quick Reply: 1998 Lexus GS400 P0172, P0130, P0133, P0150, P0153
