Low Idle in Drive HELP!!!! Check the Video
Hope someone could help with this low idle issues I've been having, with my 99 Gs400.
Cleaned Throttle body,maf and changed air filter and checked for vacuum leaks.
I'm out of ideas, right now gotta turn rear defrost or Ac to keep rpms up.
Any suggestions are appreciated.
Sorry bud, I'm thinking of the old 1uz-fe's. They dont actually have stepper motors now on the newer ones. They use the electronic throttle for the idle. So you would have to check that its working.
Also do a self diagnostic check for any possible codes.
ok i'll try that, also gonna have my alternator checked. did a multimeter test this morning (@ idle - 13.8 but with load rpm volts is 12.5)
Think the alternator is going out gonna check it at autozone and check back.
Kinda weird this is my 2nd one Power Steering fluid is not even leaking.
Bout to just bite the bullet and take it to the stealership.
In the meantime I just run the rear defroster..
ok, before you switch it out try adjusting the one thats there. Just a few taps on the two screws with a long Philips head to break them loose and then loosen. While the car is on and idling already warmed up, slightly move it, see if it improves.
technol
12
Aug 1, 2014 06:44 PM
