I have the 2jzgte vvti bought the ecu with part number 3a470 have all the parts. The car just won't start. I have the Aristo harness also. I tried searching couldn't find anything in how to convert the gs harness over. Had a guy tell me that I couldn't use the Aristo harness and to modify the gs one.
Check coils for spark, (remove one spark wire from spark plug, insert any spark in to that wire and put it on engine cover)
Check injectors for power (injectors are controlled by negative) (remove injector plug nr2, closest one, and check on it)
Check fuel pump health. (fuel pump has 2 lower pins in fuel pump plug, upper 3 are for fuel level sender.)
it takes about 10 min to do so.
all check ups have to be done on CRANK otherwise trying to start engine.
