Installing Intake question
Old Aug 31, 2012 | 03:55 PM
FinsIS250's Avatar
FinsIS250
Default maf sensor?
lol you just made me nervous with the maf sensor comment what do i need to avoid doing? Im about to start doing it now, will let yall know how it goes!
Originally Posted by Gville350
I installed my intank with the battery connected. The ECU soon learns (within minutes of normal driving) that you are sucking in more air, and the ECU conpensates for it. Just be careful with the MAF sensor!!!
Old Aug 31, 2012 | 03:58 PM
Individual's Avatar
Individual
I swapped over my intake from my '09 that was sitting for a while to my '12 a few weeks ago without having to disconnect the battery. Took less than 20 minutes, and no check engine light came on when starting it up.
Old Aug 31, 2012 | 04:09 PM
anthrax144's Avatar
anthrax144
I installed the Joe Z intake myself. Had to take it off and on multiple times since (spark plug change for one.) I've never once disconnected the battery or pulled the fuse. I guess I don't quite understand how you could mess up the MAF sensor during this process??
Old Aug 31, 2012 | 09:24 PM
Gville350's Avatar
Gville350
The MAF is a sensitive, precision sensor and it's not one you'd want to be bumping and banging around while dangling when swapping over from OEM to aftermarket. That's all guys, that's all.
Old Sep 1, 2012 | 10:56 PM
FinsIS250's Avatar
FinsIS250
Default Success!!!
i DID IT ON ME OWN,! Following the Sewell instructions, within minutes my car's tan averaged 29 mpg up from the usual 24.!
however I havent noticed the usual sucking noise i'm used to with intakes nor have i noticed my car being any faster or louder..
Old Sep 2, 2012 | 12:01 PM
FinsIS250's Avatar
FinsIS250
Default success!
Old Sep 2, 2012 | 06:27 PM
Cuztom350's Avatar
Cuztom350
You didnt plug in the MAF sensor, lol
Old Sep 2, 2012 | 07:38 PM
po1qw's Avatar
po1qw
^ im sure he did it ^..~ but yea man i recently installed my f sport intake same result... a little mpg gain and some sound at 4k rpm... not impresssed at all >:I if i known I would defiantly gotten the K&N intake Q.Q
Old Sep 2, 2012 | 07:48 PM
FinsIS250's Avatar
FinsIS250
Default yes i did plug in the maf sensor lol
If you look above it shows its plugged in, left of the intake in the bottom.
Old Sep 2, 2012 | 08:43 PM
shadowman's Avatar
shadowman
If MAF wasn't plugged in correctly, the car will sputter or stall, then throw up a CEL
FinsIS250
Performance
Aug 31, 2012 07:33 AM
LEXAUDI
Performance
Mar 20, 2011 12:12 PM
Green Zach
Performance
21
Jun 24, 2008 11:52 AM
MattIS
Performance
Jul 23, 2007 01:38 PM
WhatYaGot
Performance
Jan 11, 2007 11:38 AM
