Intake help
Old Apr 22, 2012 | 03:47 PM
bigwes's Avatar
bigwes
Default Intake help
I installed a k&n intake on my car, 2 days after I installed it my CEL came on. But after about a day or so it will turn off, then back on again. So I checked everything over and retightened everything, and double checked to make sure there was no leaks, but the CEL light still came on, then turned off, then on again. Anybody have any idea what's going on??
Old Apr 24, 2012 | 09:23 PM
goodbuds's Avatar
goodbuds
Try disconnecting the battery for about an hour, re sets the computer.
Old Apr 25, 2012 | 02:13 PM
jriggs's Avatar
jriggs
did you re oil the preoiled filter? if so you've probably soaked the maf in oil.
Check all your vac lines, if ones cracked that can cause problems, check the rubber boots after the maf, if one of those are racked it can cause problems.
showjet95
RC - 1st Gen (2015-present)
Feb 9, 2017 11:10 PM
KOKISF
IS F (2008-2014)
Feb 21, 2013 07:10 PM
mikefate
IS F (2008-2014)
12
Jul 31, 2010 09:42 AM
Guchi_Man
CL of Hawaii
Oct 27, 2009 09:05 PM
Inzane089
Dec 2, 2008 10:51 PM
