Need help Is300/2jzgte vvti getrag
Old Oct 19, 2011 | 08:27 AM
2Jayzee's Avatar
2Jayzee
Default Need help Is300/2jzgte vvti getrag
Im just about done building my daily driver , just need to paint it ..
A few quick questions for any of you with a similar set up . I have greddy BCC wired and taped correctly (its not my first rodeo) I used the center wire on map yellow/black as the wire to be intercepted. does that sound correct ? pin 9 on that block it was ..
also I set voltage to 3.9 and 4.1 still seems to have an issue ...
lastly I also have greddy speed cut limiter ,, Has anyone had any luck with this device?? Do you rememeber your dip switch settings?? thanks in adavance for any help in regards
here is where Im at today Ill have it finished and painted this week .. kind regards
http://youtu.be/gQGc7FzSjbQ
Old Oct 19, 2011 | 06:28 PM
2Jayzee's Avatar
2Jayzee
Default got r done
As usuall i answer all my own questions .. thanks anyways guys..
19psi steady , what speed limit ??
"untill the thrill of speed overcomes your fear of death, boost on!!!"
ARISTOLEX
GS - 1st Gen (1993-1997)
Jul 1, 2014 08:09 PM
is3002jzgt
IS - 1st Gen (2001-2005)
Feb 19, 2014 11:54 AM
GS300Jason
Oct 19, 2009 09:35 PM
