Those running BOV's
Old Jun 7, 2011 | 11:20 PM
vwynn's Avatar
vwynn
Default Those running BOV's
Ive been reading about how some cars with MAF's cannot run a BOV that vents to the atmosphere due to the loss of air that was already calculated by the MAF... perdy much after the BOV vents the car stalls?
does that apply to our cars? if so how do we go around it?
more specifically does it apply to a GS400 that is force induced? Placement of the BOV would be probably right after the intercooler so before the MAF.
heres the given setup:
RMM Supercharger Kit
Vortech V2
Vortech Maxflow BOV/BPV
Apexi SAFCII
Old Jun 8, 2011 | 01:26 AM
jacksonvp's Avatar
jacksonvp
Recirculate the depressurized air into the intake after the MAF?
Old Jun 8, 2011 | 12:22 PM
fastryan's Avatar
fastryan
can you put the bov before the mas ? then the vented air will never be metered.
Old Jun 8, 2011 | 04:08 PM
SlvrGS300's Avatar
SlvrGS300
use the decel air feature on your S-AFCII to compensate
Old Jun 8, 2011 | 04:09 PM
vwynn's Avatar
vwynn
thats what im thinking but im not to sure what would happen to the car if the pressure inside the pipes suddenly drops due to the venting... i will be doing that for sure tho if its reliable
Old Jun 12, 2011 | 08:17 AM
99 GS3's Avatar
99 GS3
So you've relocated your maf as a blow-thru correct?
If you are blow-thru you want the maf installed close to the throttle body post intercooler, and don't put the bov between the maf/tb. You'll want the bov far enough behind the maf to minimize turbulence, I put my bov on the hot side of the intercooler.
The stalling issue when running a maf and atmospheric dump is generally when the maf is still in a pull-thru pre-turbo/sc location.
You should be ok to dump if your blow-thru.
Old Jun 12, 2011 | 08:44 AM
GILLEXUS's Avatar
GILLEXUS
Vortech V2
Apexi SAFCII
Your correct, it has to beplaced before the MAF. If you hav a RMM Supercharger Kit it is set up like this.
Old Jun 12, 2011 | 12:31 PM
DeanGS's Avatar
DeanGS
If you have the BOV between the MAF and throttle body then you need to recirculate the BOV exhaust.
If you have the BOV before the MAF and throttle body then you can vent to atmosphere.
Throttle body ----- BOV ----- MAF : Must recirculate
Throttle body ----- MAF ----- BOV : Can vent to atmosphere
Old Jun 12, 2011 | 08:46 PM
vwynn's Avatar
vwynn
Nice info to reassure me! time to get this thing DONE! gotta buy a flange
Old Jun 13, 2011 | 05:39 AM
99 GS3's Avatar
99 GS3
I have a 2 bolt greddy style flange if your interested. The maxflow says it bolts to a greddy/hks size flange..
Old Jun 13, 2011 | 08:24 AM
vwynn's Avatar
vwynn
PM Sent for that.
lyles3
Feb 23, 2012 10:08 AM
gx470_05
GX - 1st Gen (2003-2009)
May 24, 2010 10:28 AM
StarkoS14
Dec 22, 2009 11:37 AM
gompka
GS - 1st Gen (1993-1997)
Feb 17, 2005 03:01 PM
Bean
Nov 29, 2001 11:25 AM
