Check Engine Light, VSC OFF, Code P1121
Old Mar 31, 2011 | 04:54 PM
Trouble-T's Avatar
Trouble-T
Default Check Engine Light, VSC OFF, Code P1121
Hi Everyone
I have a 1999 GS 400 and im having problems my with car. Ive had the car checked with the obd 2 meter at autozone and the code I am getting is P1121 (Accelerator Position Sensor Problem) Every two weeks for the past 3-4 months my car will lose power. Sometimes when I accelerate from a complete stop the car will get up to 45mph and suddenly slow down as if im braking. The check engine light comes on and the VSC off light. Then I will have to press the gas pedal to the floor to get it to go. Also, when this happens I go to put the car in park and the rpm goes up to 2000. Ive read some threads with people that have had this problem and they are saying for me to check the Accelerator Position Sensor or the TPS. I havent read a tread yet that says that their car raises to 2000 rpms when they put it in park. If anyone has had this problem please respond.
Old Apr 10, 2011 | 05:19 AM
GS671's Avatar
GS671
i had the same problems. I messed around with the throttle body and didnt set the TPS right. Your TPS is probably on its way out. Did you touch the TPS prior?
Stroock639
16
Jan 4, 2026 12:00 AM
01BabyLexy
Nov 25, 2022 10:04 PM
Squirrl
Performance
May 18, 2010 03:13 PM
GS-power
Nov 7, 2009 09:57 PM
relax221
Jul 24, 2009 06:59 AM
