Cam Pulley Issue
Old Dec 4, 2010 | 02:44 AM
Team Rukus's Avatar
Team Rukus
Default Cam Pulley Issue
After doing some reading i have noticed several CLers stating not to open up a Cam shaft sprocket pulley (the hex bolts) and pry it open. And if you do it means time for a new one.
Can someone answer me as to why that is?
is it because its hard to put it back together or is there a timing inside of that aswell?
if your wondering...i accidently opened it up and had a hell of a time putting it back together but i got it back together but i am just wondering why.....
Old Dec 4, 2010 | 04:10 PM
AshburnM3's Avatar
AshburnM3
you mean those 5 bolts around the VVT-i pulley? they are not suppose to be removed or you need to buy a new VVT-i pully assembly according to the manual. since you've got it back together, is your timing or VVT working properly?
Old Dec 4, 2010 | 04:22 PM
Agent0024's Avatar
Agent0024
Mine was leaking and I took it apart to seal the leak. Bolted everything back together without any problems so far.
Old Dec 4, 2010 | 04:28 PM
AshburnM3's Avatar
AshburnM3
only need to remove a 14mm hex plug, washer and a 10mm hex set bolt to remove the pulley assembly.
Old Dec 4, 2010 | 08:49 PM
Team Rukus's Avatar
Team Rukus
well i know that part just wondering as to why the manual says it. I am assuming cuz its a super pain in the *** to get it back together.
as for timing and vvt right now i am still having a problem as the car doesnt start yet. I think i set the camshaft timing wrong.
Team Rukus's Avatar
Team Rukus
did you have a hard timing pushing it back together do to the spring?
Old Dec 4, 2010 | 08:50 PM
Team Rukus's Avatar
Team Rukus
unfortunately i only figured that out AFTER lol
Old Dec 4, 2010 | 09:44 PM
Agent0024's Avatar
Agent0024
I never took the parts inside the pulley apart, I only split apart the pulley as seen in this post.
https://www.clublexus.com/forums/gs-...seal-pics.html
There wasn't any spring that I'm aware of. I simply took the 5 bolts off and took the front half of the pulley out with out letting the inner parts fall out.
Old Dec 5, 2010 | 03:44 AM
Team Rukus's Avatar
Team Rukus
oh okay that means you only took the outer pulley off. i accidently took the hex bolts off and dismantled it thinking thats how the cam timing tube will come off.
Old Dec 5, 2010 | 12:02 PM
Agent0024's Avatar
Agent0024
I took both halves off completely to replace the cam seal, the only thing I didn't do was dismantling everything like you. From what I've been reading, there's only one way to put that VVTi pulley back together so I don't it would cause any problems for you.
I didn't noticed any kind of springs when I had it apart. The inner hear slid in and out freely without any kind of resistant.
Old Dec 6, 2010 | 11:27 PM
Team Rukus's Avatar
Team Rukus
your lucky because you got the gs3 i have the v8 big boy and that pulley is different.
lets see if i can explain it a little:
when you take the pulley apart in half there is an internal gear that is bolted down to the cam shaft and then there is a spring from the timing tube pushing out at the outter half of the cam pulley. there is also a secondary gear that goes on top of the mounted gear.
so its two gears, a spring, plus the outter half of the pulley.
its completely different from the ones on the gs3
j.tom
Oct 29, 2013 11:10 AM
Doneve79
Jul 3, 2011 05:21 PM
UptownGS
Jan 20, 2011 04:34 PM
gsrell
Nov 8, 2008 06:49 PM
sorka
Jul 29, 2008 11:00 AM
