installing turbo
Old Jun 26, 2010 | 11:02 AM
ussrIS300's Avatar
ussrIS300
Question installing turbo
if i were to install a turbo from 2jz-gte supra into is300 2jz-ge would i need to modify the engine?...i mean isnt it the same engine as supra but not turbo?
Old Jun 30, 2010 | 11:58 AM
baadhabit's Avatar
baadhabit
the turbos from the GTE wont fit a GE motor. round peg square hole
Old Jul 1, 2010 | 09:49 AM
cricket056's Avatar
cricket056
SRT is your only bolt on turbo set-up. Either way if you want to push it without blowing it up you will need to tear it apart.
Old Jul 1, 2010 | 09:56 AM
Jay's Avatar
Jay
eBay stuff....
http://motors.shop.ebay.com/__?_from...bo+kit&_sacat=
IDK if kit good or bad, but it's out there !!!
Old Jul 1, 2010 | 10:05 AM
cricket056's Avatar
cricket056
^^It's garbage. More likely to mess up your engine than provide sufficient gains in hp. Piping will likely need modified and the components fail long before they should. If you like repurchasing stuff and installing it twice buy this and report back with what you blow up and have to replace.
Honestly, if you are looking to put a turbo on your car as cheaply as possible I wouldnt expect the vehicle to live through the conversion. Once in awhile you hear of someone actually doing something with one of these turbos but more often than not you hear the words shaft play or cracked housing.
GL either way. My opinion is to do it right the first time and support the vendors that help supply this and other forums.
amaz87
Performance
May 25, 2016 09:14 PM
ctfinest28
IS - 1st Gen (2001-2005)
Feb 1, 2012 06:13 PM
ca18det
GS - 1st Gen (1993-1997)
Mar 4, 2006 02:37 PM
CSHFLW
Oct 1, 2001 09:10 AM
ari1856
Performance
Jul 27, 2001 08:10 AM
