Headers...
Old May 10, 2010 | 07:04 PM
LexusGuy35's Avatar
LexusGuy35
Default Headers...
I like to get a set of headers and have a few question. Are they really that hard to install yourself, I have some mechanical ecperiance and would like to know if its something I can do in my home garage. Ive installed a set on older cameros without much trouble. Im not sure how much room there is to work on the 250 motor though. Also are the tipical ones you see on ebay crap, I would also like a set that will bolt right up to the factory pipes.
Old May 10, 2010 | 07:15 PM
iSuxeL's Avatar
iSuxeL
PPE is what you're looking for. If you can install headers on a Camaro then I'm sure you can on the IS. There's not much room in there but it's enough if your hands are small
Old May 10, 2010 | 07:18 PM
ChrISF's Avatar
ChrISF
you're going to need a lift.
Old May 10, 2010 | 07:27 PM
iSuxeL's Avatar
iSuxeL
Ramps homie!
Old May 10, 2010 | 07:29 PM
LexusGuy35's Avatar
LexusGuy35
Im pretty sure I can do it with some floor jacks if its possible.
Old May 11, 2010 | 08:09 AM
AZ JB's Avatar
AZ JB
^^This.. PPE's are awesome.
Old May 11, 2010 | 09:32 AM
Gaugster's Avatar
Gaugster
Headers can be DIY but it's gonna take some time. I did it and IIRC it took me ~9hrs. But I was alone and worked slowly.
I used jack stands in my garage. Bought an O2 socket from AutoZone. I also bought some 3/8" and 1/4" swivel sockets. I did not reuse any of the old gaskets but you probably only need new exhaust flange gaskets as these are a crush fit type.
I removed a lot of things in the engine bay but I have fat fingers and Popeye forearms. I removed the following; Engine Covers, Air box, Battery, Power Steering ECU, Front Drive Shaft(AWD only), Assorted Undercarriage Braces, Mid Pipe, Small module near the drivers side shock mount.
I was able to get a torque wrench on about 50% of the engine header bolts. I tend to shear stuff otherwise as I don't know my own strenght these days.
Hope that helps.
Old May 11, 2010 | 02:05 PM
RRocket's Avatar
RRocket
^^Lay off the spinach?
Old May 11, 2010 | 02:10 PM
iSuxeL's Avatar
iSuxeL
It took me 4hrs alone with taking my time haha
Old May 11, 2010 | 02:20 PM
chriso_86's Avatar
chriso_86
If it takes your 4 hours or 9 hours or 20 hours I think the goal is to work at a pace your comfortable with and get it done right the first time.
Old May 11, 2010 | 04:38 PM
JDKane527's Avatar
JDKane527
CL Folding 25,000
Hear yeee
Old May 11, 2010 | 05:51 PM
LexusGuy35's Avatar
LexusGuy35
Hope that helps.
Yes that does help me alot. I'm pretty sure I can do it myself, I don't think i will have to remove all that, i kinda have thin arms and fingers lol, I wont know til im at it though.
Old May 11, 2010 | 05:55 PM
LexusGuy35's Avatar
LexusGuy35
Oh a few quick question. Which headers did you get and how do u like the pROrmamce? Did they bolt right up to the stock pipes? Also hows the sound and do U have cat back exhaust aswell? My car is a rear wheel drive so I shoul be alittle easier:P
Old May 11, 2010 | 07:50 PM
montgb's Avatar
montgb
^^^ I have the PPE headers. Not sure about performance since I still need to dyno, but I sure didn't lose anything. They bolt up to the stock pipes and the sound is heaven (I have stock mid and HKS Hi Power axle back). But you will throw CELs unless you take steps to remedy it.
Old May 12, 2010 | 07:15 AM
Gaugster's Avatar
Gaugster
You can have a look at the link in my sig' for all the 411 about the Mazurri AWD headers that I have.
Sadly, he is not in business anymore so my experience may not be the same as yours.
I really like the sound of the headers. I did pick up a bit of power per the 1/4 testing that I did. The most notable performance boost is a lot more low end power which is great for an AWD.
