Installing ecu?
Old Jun 14, 2002 | 09:25 PM
bigbllr2000's Avatar
bigbllr2000
Default Installing ecu?
i wanted to see if anyone attempted to add ecu and what tools you'll need and how long it might take i am going to be recieving srt intake and ecu just want to get a heads up thanks,
Old Jun 15, 2002 | 03:17 AM
Mean Gene's Avatar
Mean Gene
Thumbs up EZ
Big - It's been awhile but all it took was a soldering iron, small drill bit/drill & wire cutters ( plus some patience - rather tight working area but still easily done ). If U're not handy with a soldering gun then check with your local stereo store & one of their installers should be able to follow the diagram. Good luck & enjoy the intake!
Old Jun 15, 2002 | 07:00 AM
bigbllr2000
thanks i should e receiving it in about a week i will go for it...
Old Jun 15, 2002 | 07:54 AM
lexlyf's Avatar
lexlyf
Just as Gene posted, if you're handy w/ wiring & soldering, then it shouldn't take more than a hour to hour and half.
If not, it wil take a litle longer, but if this is your situation, I would probably seek service from a stereo shop like Gene suggested.
Old Jun 18, 2002 | 11:13 PM
bigbllr2000
hi i really need jelp just installed ecu and my car boggs at 3000rpm's drove for about 20 miles and now it wont start please give me some advice?
Old Jun 20, 2002 | 12:53 PM
bravo261's Avatar
bravo261
can anybody help him? this sounds ugly and i'm wondering about it also since i may have to install the ecu myself
Old Jun 25, 2002 | 01:04 PM
lexlyf's Avatar
lexlyf
In future, when needing more immediate diagnostic attention, PM me or call the SRT facility directly at (301) 384-7319, as I didn't see this thread earlier.
What's the status of the SRT Ecu being installed in your car? How did everythnig work out?
Normally 1 of 2 things, or both happen during the installtion process of hte SRT Intake System w/ Race Ecu:
(1) Incorrect wiring. Please be sure to recheck all of your connections according to the directions.
(2) Disconnect the negative battery terminal after wiring the SRT piggy Ecu for approximately 15-20 minutes.
If neither of these troubleshooting methods achieve resolution, please contact me so that it can be corrected.
Old Jun 25, 2002 | 07:04 PM
bigbllr2000
thanks i didnt no but i was rushed when doing it, it took me all of 1 hour to do everything and the hardest part believe it or not was the intake cuz is so tight of a fit, so i called srt and they said it soundeed like the wires were reversed but i was pretty sure i did everything right to my dismay the only wire you cut i had soldered to the wrong color but the car still started so i was very impressed with that and didnt want to look dumb just a rushing mistake cuz it was 12:30 on a work night and i still had to take 1 of my buddies home that was watching me do it. he thought i was crazy cutting into my wires, i told him i had complete confidence though cuz i have done alot of soldering in my days previous hehe thanks though.
Old Jun 25, 2002 | 07:51 PM
lexlyf's Avatar
lexlyf
OK. So all is well, right? Just want to be sure that you are putting yourself in the best scenario to experience the performance of the intake system.
Old Jun 29, 2002 | 05:46 PM
bigbllr2000
yes i did it correctly now thanks for checking with me?
Old Jun 29, 2002 | 05:55 PM
Hermosa's Avatar
Hermosa
FYI, getting a butane soldering iron will help alot. You can get one at Radio Shack. Having to work with an electric soldering iron can be awkward especially with your face squeezed between a big pile of pulled up carpet and your glove compartment. Also remember to use the better quality solder for electronics.
Old Jul 1, 2002 | 07:51 AM
lexlyf's Avatar
lexlyf
Hermosa:
I like working with those small butane slodering guns. They are extremely easy to handle & allow you to get in all of those cramped spaces.
Old Jul 1, 2002 | 05:22 PM
garnet92's Avatar
garnet92
Default Different ecu
Unless something's changed with the new "race" ecu (which I still haven't received, Marken), the SRT ecu referred to is in engine compartment - not the steering ecu under the dash, so under-dash isn't the problem. It's just that the wiring bundles are pretty tightly packed so getting enough slack to cut, splice, and solder is a little troublesome. Correct me if this is wrong.
Old Jul 1, 2002 | 06:47 PM
lexlyf's Avatar
lexlyf
I was only talking about the use of the miniture butane torch...not referring to any particular type of install or product.
Old Jul 7, 2002 | 01:18 PM
fireballs gs400's Avatar
fireballs gs400
Thumbs up questions about parts
curious about the steering ecu. what does it produce? the performance aspects are? the venom 400 any good on the lexus gs400. How about the jet chip? just wondering what some of the big dogs thought about these things. thanks bryan
