Question CAR WON'T START
Old May 6, 2010 | 01:07 PM
  #31
scooter58's Avatar
scooter58
fuel or spark... that is the problem
Old May 6, 2010 | 05:14 PM
  #32
duby1's Avatar
duby1
where would i check the fuse at? Which one? The one near the foot area under my under neath my dashboard or the fuse box next to the battery?
Old May 6, 2010 | 06:23 PM
  #33
TomLee's Avatar
TomLee
I left my gs untouched for about two months and it would barely start up, i had to gas it at the right time to get it to start up haha. I dont know what wrong with yours but good luck man!!! And welcome to the air club!
  #34
TomLee's Avatar
TomLee
i just watched the video....just press the gas pedal a bit when you start it!
Old May 6, 2010 | 06:24 PM
  #35
TomLee's Avatar
TomLee
oh....and LOL@ pressing all the buttons on the climate
Old May 6, 2010 | 06:55 PM
  #36
gzhottt's Avatar
gzhottt
video is smart lol ..all i know is..if its your starter thats going to be bad news dude..$500 easy..towed to mechanic (not dealer) let them deal with it. GL
Old May 8, 2010 | 09:01 PM
  #37
duby1's Avatar
duby1
yea, i got a guy came by... he says it might be my computer ECU... blah wonder how much is this is going to cost me.
Old May 11, 2010 | 04:09 AM
  #38
redred's Avatar
redred
Hope it's not the ECU. Did you try leaving the ignition on for >6 minutes?
Old May 11, 2010 | 07:55 AM
  #39
3UZFTE's Avatar
3UZFTE
Dude, if he isn't sure, don't just spend money on a computer. If you don't have somebody who can check the fuel pump, then I wouldn't have them check the ECU. My bet is that the ECU is functioning fine, it does everything else but fire the motor, which leads me to believe that the ECU is OK. Second, since the vehicle pulled in and didn't pull out, chance are something that you happened to do changed the way the vehicle operates. Take a digital volt meter, go back to the fuel pump and see if your getting 12v, then you can eliminate the wiring.
Air: Check mass air flow sensor, connections, etc, like someone mentioned, MAF would start, but die.
Fuel: You will need a fuel pressure tester, which is a gauge that "t's" into the fuel line. Also measure the resistance of the fuel pump according to Alldata or the TSRM (Toyota Service Repair Manual) Also like someone mentioned, go back check your fuel lines for visual damage, etc.
Spark: It's pretty difficult for our COP (coil over plugs) to lose spark to all 8 coils, so as everyone mentioned check the fuse(s), and that should be OK, but use a plug tester if you need to, their cheap.
My guess is fuel.
Old May 11, 2010 | 10:07 AM
  #40
denut-L's Avatar
denut-L
Before buying a ecu, try to see if you can borrow one from somebody and try to see if that would work or maybe check the ecu fuse.
GL
Old May 11, 2010 | 04:00 PM
  #41
duby1's Avatar
duby1
i can't borrow a ECU from someone else. I would need a new key to start up the car.
But what's not making any sense is... Ive started the car 2/3 weeks before the UAS installation and it work fine and now when i try started it... it won't fire up. i double check the fuel line and everything is working perfect.
Old May 11, 2010 | 04:17 PM
  #42
LudeNsoL's Avatar
LudeNsoL
damn man that really sucks... hope you figure it out
LexusFlex6
May 18, 2021 04:49 AM
tofuprod
Jan 28, 2019 06:58 AM
ltran82
Jul 15, 2012 07:41 AM
e-man
Feb 22, 2010 10:12 AM
Alexusoftime
May 16, 2006 11:46 AM
