Dyno 4/15/10
Something to think about before going to get a tune that's for sure. A co-worker of mines also told me that i should of got gas at BP or shell before the tune because superamerica's gas is like crap " that's where i pumped before the dyno" He said SA's gas will pull timing as alot of people have been having this issue with the cheap superamerica gas.Dyno run #1
http://www.youtube.com/watch?v=_66NvpgBNDU
Dyno run #2, #3, and #4..
http://www.youtube.com/watch?v=wOrLSfdhC_w
Dyno run #5 after everything was cooled down...
http://www.youtube.com/watch?v=QkGYiWKQRdM
And backing out of the dyno...
http://www.youtube.com/watch?v=dtnywGJtKwI
Well as for numbers i haven't got the email from jordan yet so no graph to show you guys. But if i remember it was something like 27o something whp and 28o something wtq. I totally forgot, but it was in that ball park. I'll post up the dyno sheet as soon as i get it from MAP.
Well overall i'm not to happy about the money that went into this motor, but in the end if you think about it, the mods that was put on, the numbers are not that bad. Plus low to mid range, feels great! The addition of the headers made a difference in the mid range powerband as you'll see it on the dyno sheet compare to the last dyno pulls.
Well see how the car runs after a couple weeks and if it feels different in any way, i'm heading back to do a couple dyno pulls to see if the numbers changed at all.
Here is my journey to 27o-280 whp
Stock 235-240whp
Injen Intake - rear l-tuned mufflers w/o tune - 245whp
Injen intake - L-tuned rear mufflers w/tune - 255 whp
Injen intake - 3" Magnaflow race mufflers - 2.5" full catback custom x-pipe/Tune - 261whp - 279wtq
Injen intake - SS headers - 3" Magnaflow race mufflers - 2.5" full catback custom x-pipe/Tune 27o-280 whp - 28o something tq
Grand total of $3018.96 including labor = 35whp
Not worth it IMO.I will enjoy this setup for 2010 and will not be putting anymore money into this engine and will be looking to move on to another project
BTW Rock, how are your headers doing? any sign's of cracks yet? Now that i got these on i'm starting to wounder when will they let go.
I should of wait also for the ecu to learn, but i guess i'm a very impatience guy. Now i wounder if it would of made better numbers if i waited
Something to think about before going to get a tune that's for sure. A co-worker of mines also told me that i should of got gas at BP or shell before the tune because superamerica's gas is like crap " that's where i pumped before the dyno" He said SA's gas will pull timing as alot of people have been having this issue with the cheap superamerica gas.Thanks Tim, The only down side to these headers is the install and cost
I'm not sure how you would do that but it could be possible, not much room to work around. I would keep the OEM one's just in case these CRACK.
The engine mounts look easy and if anyone wanna do this job by themselves looks like it would be best to remove the engine mounts. After the mounts are removed there is so much room to work around to get the bolts off the manifold. Looks like Yang just took the bolts off from the bottom and lifted the engine up from underneath a little to remove them. Also have to remove the bolts that mounts to the block.
Yeah the hard ones are the bolts holding the motor mounts to the block.
LOL!! Dude your Vette is just crazy
Stock 235-240whp
Also, to everyone modding:
DO NOT FORGET, if you spend $3,000 to get 30whp this may sound like it sucks but is really doesn't! This is roughly $100/whp. What do you think you would get with a supercharger or turbocharger setup?
Supercharger - Adds around 100whp. For a PROPER setup supercharger, when it's all said and done you will be DAMN near close to spending $10K or...$100/whp!!!
Turbocharger - Adds 150+whp. Let's say you get a turbo setup that ADDS 200whp. Now, from STOCK levels you are now rolling aroun 450whp. Guess what? To properly execute this setup you will be dropping damn near close to $20K!!! (don't forget with this much MORE power now you will have to beef up the transmission and perhaps even the stock brakes). This again arrives you at $100/whp!!!
The cheapest mod per whp will ALWAYS be nitrous. Although not perminent (or safe for the health of the engine) a 100 SHOT of nitrous ADDS roughly 100whp. A nitrous setup done properly would probably run around $1000-$1500 or $10-15/whp.
If it is your WEEKEND CAR and you want to keep costs down by NOT going FI I would do EVERY BOLT-ON POSSIBLE and a small 50 shot of nitrous. Just enough to allow you to hang with the faster cars that much better without putting a strain on the engine at all!
I am going to be following this path soon (waiting on revised headers from PE) and I am looking for results like this. Also like Rock said.. you need a tad more.. drop in a 50 shot!
You'll love this setup and GL on your path to the upper 200whp 200wtq 4.3L
and keep us updated.
gotta put my ss headers, srt intake, ls400 bbk, stereo and speakers... etc...
eventually, I'll get to do my ls460 projectors low beam and projector fogs. I already did the LSD (so worth it when you have more power).
Oh i see, did you ever dyno'd yours before? NUmbers please and do you have a dyno sheet i can look at to compare the powerband to mines? Your's a 430 right. I'm gonna most definitly get lsd in here sooner or later but still deciding if i wanna keep the 3.9gearing or go back to the 3.2gears. I hate not being able to go over 135mph. Sam what diff do you have in yours?
I'm glad to hear this, i've looked under and there sure looks like alot more room to work around that's for sure.
I'm doing Stock gs430 gear on my LSD for the same reason you cited,and for future power increases. Although, RMMGS4 mentioned that his car seems to hit the power range better with the supra auto gear (same gearing as rock). I don't know if Glenn is describing his sweat spot pre-supercharging or not. Hopefully he reads this and comment.
My stocky is not really taking advantage of the LSD on gs430 gear, unless brake torqued... but I did it because the SS and SRT will be back in. Also, I feel that we no longer need VSC as it's more of a detriment to performance than anything else after installing LSD (except during rainy season LOL).
After the headers bolted on, reaching cut-off is much quicker then before and that takes the fun away. Also every time it shifts the rpm drops to above where i make most hp and tq. now that doesn't seem like a good thing does it? If you mentioned that the supra diff drops it into the powerband everytime the car shifts then that's what i'm looking for. It's been awhile since i had my stock gears in to remember but from what i can recall is after going into 3rd and 4th the car feels great in those gears. now could it be the longer gears putting the engine into the power band at that time, I don't know. But i can say that with the 3.9gears i don't really feel that even with the setup that i have now. The 3rd gear just zips by like nothing and then 4th last a little longer and 5th tops out at 135 in no time at all. I guess i'm gonna try to look for a supra diff, but in the mean time i'm gonna throw my stock diff back in and see how it responds to my new mods and tune.
