Transmission Snow Mode
Old Mar 12, 2001 | 09:42 AM
blan's Avatar
blan
Question
How does the "Snow" mode differ from normal, on a GS 430.
I feel that it keeps the engine at lower RPMs and seems to deliver less power. It just feels different, but I am trying to understand what it does.
The manual is a little (OK, a lot) moot on this subject.
Oh, should I use this mode in rain, too?
Thanks.
Old Mar 12, 2001 | 01:30 PM
fever's Avatar
fever
I believe it starts the car in second gear and certainly does keep rpms and acceleration low.
Old Mar 12, 2001 | 08:00 PM
RealMarty's Avatar
RealMarty
Its starting in second to put less torque to the rear wheels and thus, reduce the possibility of wheel slippage (and engaging the traction control) when you have snow or ice under the rear tires.
It feels like less power because of the higher gear. The car is trying to help your tires stay connected to the road and maximize your control.
In the rain your tire is touching the pavement so launch traction shouldn't be a problem. I don't see the need or what the advantage would be to use the snow setting in the rain.
Marty
Old May 8, 2001 | 11:07 AM
Black_IS300's Avatar
Black_IS300
The snow mode in the IS300 will only open the throttle to 65%, so even if you floor it you are only getting 65 %throttle. The reason I know this is because my AFC tells me the % throttle. Im sure its similar in the GS.
fnthawar
Jan 3, 2025 12:09 PM
CAMAracer
Aug 9, 2008 01:32 PM
J1 IS300
IS - 1st Gen (2001-2005)
Jan 10, 2005 02:53 AM
Mikeswing
Feb 25, 2003 09:50 PM
gsnav
Feb 8, 2002 03:40 PM
